diyAudio Sponsor
Old 5th August 2007, 11:51 AM   #1
engels is offline engels  Israel
engels's Avatar
Question Tube current regulation for series heaters' supply.
I've got a bunch of compactron tubes that I want to put into PP use. The heaters on these tubes require various funky voltages (21, 33, 38 V) at 0.45A. I've got pairs of 21GY5 (21V) and 33GY7A (33V).
I thought about building a series heater supply for those tubes which asks for a 45mA current regulator. I haven't done tube current regulators before and I don't even know which type does 45mA. There are nice & cheap octal ballast tubes like URB-001, 002, 003 ... 010 but I miss some explanation how to get a desired current out of them.
Of course, I'm not wiring them to the mains, I will probably use a 24V tranny with 1.5-2A rating.
The first option that comes to my mind is probably 24V AC bridge rectified to 33V for a parallel supply, but I still wonder about tube current regulation.
Old 5th August 2007, 12:40 PM   #2
SY's Avatar
Why use a tube there? The drop is pretty high for these low voltages. A transistor or FET will perform much better in that application.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th August 2007, 02:20 PM   #3
d2134 is offline d2134  Romania
Send a message via Yahoo to d2134
21GY5 and 33GY7A need 450 mA ! A transistor CCS is more suitable at this current.
Old 5th August 2007, 04:53 PM   #4
engels's Avatar
Default sorry
first, sorry for 45 instead of 450.
0.45A
But don't you think fets also perform much better in the audio output?
Old 5th August 2007, 10:49 PM   #5
jnb is offline jnb  Australia
Default Re: sorry
I don't think a solid state current regulator for your heaters is a bad idea as the heaters are not really in the signal path.
PL519 Heaters in series blow fuse wiysel Tubes / Valves 5 6th November 2008 11:18 AM
Tube heaters in series. nigelwright7557 Tubes / Valves 5 4th July 2008 09:11 PM
Tube filaments (heaters) power supply matejS Tubes / Valves 5 12th July 2007 05:50 PM
Series heaters = small problem? Klimon Tubes / Valves 5 13th May 2007 11:12 AM
Series wiring for heaters XZur Tubes / Valves 5 19th December 2005 02:43 AM
Page generated in 2.08570 seconds (2.93% PHP - 97.07% MySQL) with 10 queries
