Audio Research MCP 33
Old 17th December 2005, 02:28 PM   #11
reinhard is offline reinhard
OK Brian, thank you.
Have just ordered the third edition via amazon. hope I get it before christmas.
Reinhard
Old 20th December 2005, 06:57 AM   #12
Hello,
received Morgan Jones third edition yesterday. up to now I had only a look at the LED bias, simple, will give it a try and some measurments.
Conrad Johnson use a 100 pf Mica in parallel to their Cathode
bias stack.
Reinhard
Old 2nd January 2006, 06:04 AM   #13
Hello,
always looking for better step ups!
Anyone that has experience with the SOLO step up from Ys-audio?
Uses a single 6N3, S/N better 99 dB? From Datasheet. Is that true? Hmmmmmmmmm?
Anyone with the schematic of that?
Reinhard
Old 7th June 2013, 09:13 AM   #14
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by reinhard View Post
I think I donīt try the MCP. Iīm not really happy with that big caps in such a sensitive position at the input.
Reinhard
What is here the main disadvantage (except the fact, that more space is necessary) ?
For me this is the best solution to protect the MC cartridge coils against DC. Except the approach with a step up transformer there are no other approaches with DC protect.
Even by the use of electrolytic (polarized) caps at the input (like Mark Levinsons JC-1) I don't note losses in sonic quality.
Old 7th June 2013, 09:40 AM   #15
Dann mach das doch einfach so!
Old 7th June 2013, 10:52 PM   #16
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Every circuit has its sonic fingerprint just as all passive components do, x-formers included.
Given that this is a MC pre-preamplifier with high gain, a cap at the input will carry its sonic signature right across the entire amplification chain.
It's not that hard to avoid this input cap. Given the low output of the MC cartridge and knowing that a 6DJ8 can easily be run at Vg0 as well as at slightly positive grid voltages, you simply ground the cathode.
The reason why you may not be able to hear the impact of the input cap
may well be your use of a very low value Vgin resistor to load your cartridge. However, do keep in mind that as input resistance rises so will the audibility of the cap. A component avoided in the signal path is a good thing.
Some years ago (tempus fugit) I offered a schematic of a MC headamp which I nicknamed "MC Hammer". Not sure if all the SS parts are still around but it may give some idea of how to beat some prejudices you seem to be holding.
Me, I never heard a x-former coupled MC system that sounded truly transparent. Granted, nothing ever is but still...
Frank
Old 8th June 2013, 01:42 AM   #17
Brian Beck is offline Brian Beck  United States
Brian Beck's Avatar
Aside from possible sonic degradation from the big input caps, I have another concern. These caps "block DC" only after the circuit has warmed up and settled to its quiescent condition. 82uF is connected between the moving coils and the paralleled cathodes of the input stage. At power up those caps have to be charged to about 1.2 volts at the cathode end. The charging current is supplied by the cathodes, but that same current must also flow through the coils of the cartridge. At power down, the reverse happens. Some of the charging current will be shunted into the input loading resistors, depending on what value of loading was selected. Still, a momentary pulse of some amount of current will flow into the delicate cartridge before "DC blocking" eventually takes place. It's obviously not enough to fuse the coil wire, but it might induce a residual magnetic charge in the armature or in other part of the cartridge's magnetic circuit. I can't say for sure that this would be a problem for every (or any) cartridge, but if I'd just dropped $5K on a fancy cartridge I might think twice about the situation.
I suppose you could add a normally-closed relay to short the input until the circuit settles, but this seems like a bandaid, and maybe not foolproof during a short power outage or brown-out.
Brian
Old 9th June 2013, 09:53 AM   #18
Thank you for your advices. Is the schematic of the "MC Hammer" to find on the web? Maybe similar to this:
Moving Coil Cartridge Head Amps
In this case also this thread is of interest:
Tube Phono stage dilema
Interesting advice. In this case this threads are of interest:
Allowable DC Current for a Phono Cartridge
http://www.diyaudio.com/forums/analo...-damaging.html
Old 9th June 2013, 02:14 PM   #19
Brian Beck's Avatar
If you are the proud owner of an ARC MCP-33, you can run this little test. Look closely at your cartridge's cantilever while you flick on the power switch. If the cantilever gives you a little "Hello there" nod, you might have a problem
Of course, a "head amp" like the MCP-33 is intended to be used in lieu of an input transformer. If there were ever a situation in audio for which a transformer is ideally suited, it's probably in the MC front-end. Best possible noise performance, "DC" blocking, ground-loop stopping...
But...I laugh my evil paranoia-inducing laugh... an input transformer will not necessarily protect your MC from current pulses at turn-on or turn-off if the active circuit induces pulses of current into the secondary. Transformers and caps block "DC", yes, but as an old professor of mine once said "there is no such thing as DC in the real world".
As a more general comment, the turn-on and turn-off behavior of active circuits, tubes and solid-state, is often overlooked, even by seasoned manufacturers. And how do circuits respond to rapid power cycling and brown-outs such as a nasty thunderstorm might cause? Well, another topic for another thread...
Brian
Old 9th June 2013, 07:46 PM   #20
Interesting considerations. This means in case of circuits with low impedance inputs the necessity to use the input as output (by connection to the line input of an integrated amp e. g.) for checking out the turn-on and turn-off behavior and steps to eliminate any unwanted poppings through transients.
I have sometimes heard from cracked coils in MC cartridges without having had a reason for this. Whether it was this or whether it was corrosion - that is the question.
Audio Research MCP 33Hide this!Advertise here!
Audio Research D-90 rudy129 Tubes / Valves 4 11th June 2010 01:19 PM
Audio Research lawbadman Tubes / Valves 26 2nd November 2007 03:49 PM
Audio Research D 400 MK 1 Alex helge Solid State 1 21st May 2005 04:50 AM
Audio Research LS7 kirc Tubes / Valves 0 21st October 2004 01:07 PM
Audio Research LS2 Lourens Tubes / Valves 2 4th April 2004 07:42 PM
Copyright ©1999-2017 diyAudio
