Old 2nd February 2003, 10:54 PM   #11
diyAudio Senior Member
fdegrove's Avatar
Default 6H30
Perugini made this design
Jaap,
Can you tell us more about this circuit?
Where you found it and what it was designed for etc.,please?
Tone,
There is little point for you to start building anything at this stage yet.
All,
Is a de-emphasis always used on DACs?
I can't recall having seen one on the Sheldon Stokes design...if one is used,is it always the same passive circuit?
Obviously I am no Digital Wizzkid,
Frank
Old 3rd February 2003, 05:44 AM   #12
Default Volume control
Hello,
the pot in the Perugini circuit is not a volume control, the resistance is used to make the Current Voltage conversion.
Reinhard
Old 3rd February 2003, 07:01 PM   #13
tone's Avatar
Send a message via ICQ to tone
Default TDA1541A S1 Pcb layout.
hi all,
work out the pcb today..four different file, attach it together...Messy!!
>Receiver/digital coupler/kusunoki Asy-clock/Dac.
signal hard-wire with silver wire..output stage not yet..
Old 3rd February 2003, 07:03 PM   #14
tone's Avatar
not according to scale ofcourse..
tone
Old 4th February 2003, 04:06 PM   #15
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default the perugini design
is indeed the analog stage after the dac chip and it uses the 6H30. This was the question.
The pot at the front is for the i/v conversion. After you have tried it for the right resistance you can exchange it for a normal resistor.
I have tried this design and it has a very neutral character, I had no complains, it works fine.
Jaap
Old 4th February 2003, 08:53 PM   #16
Joel is offline Joel  United States
Joel's Avatar
Default Re: Volume control
Originally posted by reinhard
...the pot in the Perugini circuit is not a volume control, the resistance is used to make the Current Voltage conversion.
Reinhard, can you explain that? I don't know what you mean by "current voltage conversion".
Old 4th February 2003, 09:12 PM   #17
fdegrove's Avatar
Default I/V.
Joel,
For a DAC to work properly you need to convert current to voltage.
A shunt resistor is one of the possible methods.
I am no digital expert but if you care to dip into the "Digital" section you'll find miles of "bones" to chew on.
Frank
Old 4th February 2003, 09:28 PM   #18
Brett's Avatar
Default Re: Re: Volume control
Joel, some DACs output a <i>current</i> that's proportional to the digital input. The TDA1541, PCM63 and a number of others are current output, whereas many others are voltage out. These Vout models use feedback around an opamp to do the I to V conversion, with the opamp being built onto the chip substrate.
In this case the pot, or a resistor will generate a voltage from the current output of the DAC, which is then amplified to a suitable level. Iout DACs put out less than 2mA for 0dBFSD.
HTH
Old 6th February 2003, 04:15 PM   #19
On my site you can find a dac tube output circuit using a pair of E182CC, these tube is the same as the 6H30 (russian code) an can be also substitute with the ECC99
ciao
Filippo
www.audiofanatic.it
Old 6th February 2003, 05:07 PM   #20
tone's Avatar
Default thanks guys
rgds
tone
DNM Power Amp Circuit Diagrams Wanted mozfet Solid State 3 29th August 2009 09:10 PM
Hepl me circuit 6h30 dia thien thai Tubes / Valves 8 2nd December 2008 01:53 PM
Pre-Amp ...... Help wanted with Circuit poynton Solid State 5 19th June 2008 02:29 PM
Simple Magic Eye Circuit Wanted poynton Tubes / Valves 7 3rd January 2008 08:29 PM
PP EL34 circuit wanted Norris Wilson Tubes / Valves 3 9th August 2007 11:29 AM
Copyright ©1999-2013 diyAudio
