Got oddball tubes! Got oddball tubes! - Page 2 - diyAudio
Got oddball tubes!
Got oddball tubes!
Old 2nd August 2007, 06:06 PM   #11
Geek is offline Geek
Geek's Avatar
Originally posted by ilimzn
1X2B is a high voltage rectifier for TV CRT tubes. To be quite honest, you can probably chuck them in the bin, they are of little use but for the purpose they were designed.
They make X-rays
I've also seen them used as o'scope CRT rectifiers in the 1K-3K voltage range and I was mad once (once?) and made an ionizer rectifier for an igition coil.
Then there's BB gun fodder..... *pock*
Lotsa uses!
Old 2nd August 2007, 10:48 PM   #12
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I wonder what the stripe of green paint is all about on the 33GY7s. I have some RCA LL500 horizontal deflection tubes with the same kind of stripe, same color. The glass envelopes are especially thick on those tubes, with a molding seam.
Old 3rd August 2007, 12:58 AM   #13
Geek's Avatar
That's an electrically conductive shorting ring. Most of the post '65 sweeps had them as it reduced oscillations by acting like a shorted turn of an inductor, keeping much of the stray gwiddledip out of the circuitry below.
Got oddball tubes!Hide this!Advertise here!
Oddball Sweep tubes in PP mashaffer Tubes / Valves 8 4th June 2009 01:17 AM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Oddball Console Amplifier kevinkr Tubes / Valves 17 29th July 2008 10:16 AM
Free oddball tubes! isaacc7 Swap Meet 7 18th October 2007 01:42 PM
FS oddball tube amp for parts woody Swap Meet 5 13th May 2007 10:39 PM
Copyright ©1999-2017 diyAudio
