diyAudio Sponsor
Old 1st August 2007, 05:47 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Circuit indentification
Guys, what this 6DJ8 circuit called, and is there somewhere that explains how it works and how good/bad it is, it drives (C14 .47uf)a 10megohm video buffer called a BUF03, I lowered the 10meg input resistor to 510k as it was flapping the woofer a bit at <1hz
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 1st August 2007, 02:25 PM   #2
oshifis is offline oshifis  Hungary
I don't know the name, but it is a high-input impedance FET gain stage driving a common-grid tube stage. This configuration has high gain with very high bandwidth due to the low Miller capacitance of the tube.
Old 1st August 2007, 02:47 PM   #3
frugal-phile(tm)
planet10's Avatar
Looks like a variation on a cascode to me....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st August 2007, 03:50 PM   #4
KaDe is offline KaDe  Germany
KaDe's Avatar
George,
that cascode-stage should work fine as phono input.
Very low noise and high gain.
I use a similar in one of my phono-preamps with good results.
The FET is sonicaly invisible.
What´s your application to it ?
Klaus
Old 1st August 2007, 04:04 PM   #5
SY's Avatar
dave
Not even a variation, it's a plain old cascode.
Its potential bandwidth can only be realized if its output loading is very light- output impedance is roughly equal to the plate load resistor. A BUF03 is welcome there.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 1st August 2007, 04:43 PM   #6
Klaus
A Counterpoint SAx000 ?
Old 1st August 2007, 05:12 PM   #7
KaDe's Avatar
Yes,
Counterpoint SA-9 Phono and the SA-11 Control amps from 1990
had this gain-stages also.
- some full house equipment btw -
Old 1st August 2007, 05:26 PM   #8
Yes,
Thought they were all glass, mostly octal, right down to the psu.
Old 1st August 2007, 06:17 PM   #9
KaDe's Avatar
Here is a scan from an old magazin with the Conuterpoint SA-9 Phono case.
Most of the glass is working in the psu at the back side.
In the front four 6DJ8 with solid state assistance.
Old 1st August 2007, 08:28 PM   #10
georgehifi's Avatar
RFBRW get's the cigar for "id"ing first, yes it's a Counterpoint SA3000 that I snaffled. it actually has six in total BUF03's, 4 x in the phono section along with 2 x 6922's and two on the output along with 2 x 6922's.
I haven't tried the phono but the line stage sounds superb very powerful transparent tight and smooth. This is one of the best tube sounds I have heard.
I lowered the input resistor from 10meg to 680k because of wandering subsonic dc getting through the .47 cap , SY seems to think that maybe the bandwidth has been compromised now that I've lowered it to 680k. It was flat out to 300khz before, but I didn't check it after the resistor change. Still sounds like it's going very high in frequency.
Cheers George
Need help on EQ circuit Buzzy Parts 3 25th September 2007 02:52 PM
Help finding TS parameter/driver indentification please (pics) > beady Multi-Way 2 1st August 2005 09:41 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Zener diode indentification! bbakota2000 Parts 2 22nd March 2004 11:55 PM
Help with a circuit Petman Tubes / Valves 9 6th February 2003 01:51 PM
Page generated in 0.10318 seconds (77.56% PHP - 22.44% MySQL) with 11 queries
