| diyAudio Sponsor | ||
I have some Zener diodes and 6080 tubes. I'm thinking to build a regulated PSU around 250v for a headphone amp. What is the simplest way?
#2 |
diyAudio Moderator Emeritus
Without starting an argument about the need or otherwise for a regulating the PS of headphone amp, the best approach would be a parallel regulator with a suitable series resistor, either using series zeners across the output or using the tube with a zener in its cathode and a voltage divider to its grid across the output.
#3 |
I also have some 6080 I would like to use. Plus I have some voltage reference tubes 5651 it would be good to use. I found this schematic but any comments would be appreciated.
#4 |
Steve Bench has a series on regulators that should give you some ideas
http://members.aol.com/sbench/reg1.html |
| Choke loaded PSU versus VR tube regulated PSU? | G | Tubes / Valves | 37 | 20th March 2008 10:45 PM |
| Is it possible to use regulated DC for a rectifier tube? | jarthel | Tubes / Valves | 10 | 15th June 2006 01:33 AM |
| Regulated psu for tube preamp | wuffer | Tubes / Valves | 21 | 15th October 2005 05:22 AM |
| Regulated Supplies in Tube Amps | runeight | Tubes / Valves | 88 | 2nd October 2003 04:01 PM |
| Regulated vacuum tube rectifier cct. | Circlotron | Tubes / Valves | 5 | 14th May 2003 03:21 PM |
| Page generated in 0.06735 seconds (69.98% PHP - 30.02% MySQL) with 11 queries |
