Old 4th August 2007, 12:52 PM   #11
jackinnj's Avatar
Originally posted by nhuwar
For b+ on the output tubes i am going to use rg58 with mhv connectors.
Nick
If you use RG58 or RG59 for HV the PTFE insulated variety is recommended.
The "bundle" on my Hallicrafters HT-45A "Loudenboomer" uses vinyl tubing.
Old 4th August 2007, 01:35 PM   #12
Send a message via AIM to DigitalJunkie
The B+ wire is 1kV rated and the rest is 600V. All are stuck in some heat-shrink.
Sounds like what I've done with my RA-100a project
With +/- 600V supplies(!),I'm not playin around.
All wire is rated 1kV or 600V.Anything with a high-potential on it gets extra insulation-from some cat-5 cable and/or heatshrink.
Also,all the traces/solder points on the boards,and the octal output tube sockets get a coating of clear nail polish ( ) just to help insulate them,and prevent any arc-over.
Maybe it seems overboard,but 1200V can REALLY ruin your day.
Old 5th August 2007, 03:41 PM   #13
Originally posted by dsavitsk
Anyhow, I know people (SY in particular) don't like the use of XLR connectors as power connectors (SY likes to say it is when, not if you will plug the wrong thing in the wrong place) but I can't get my 3 prong audio connectors to connect to the 5 prong XLR connectors I bought for power a while back, so I may just use them here. The Amphenols may have to wait until I build something larger and more military ready ...
Eeek, 5 pin XLR means DMX control line to me... I haven't seen them used on new gear in a long time but you used to see pieces of equipment with special 3 pin XLR connectors specially designed to be safe for 240V, even on the male plugs. I saw them used on 16mm projection equipment, among other things. I don't know if they are still available, but they could be useful.
Old 5th August 2007, 05:01 PM   #14
nhuwar is offline nhuwar  United States
nhuwar's Avatar
My current amp that uses 1kv b+ as I said will have rg58 in the umbilical.
But inside the amp and on the bread board I'm currently using wire rated for 40kvdc 20 gauge just for safety while bread boarding.
When then supply chassis is built all hv connections will not have nail polish on them but will have corona dope covering them.
The thing is I am well experienced in working with very high voltages so it definitely comes in handy here.
Nick
Old 5th August 2007, 05:14 PM   #15
dsavitsk's Avatar
Datasheet says they are good to 350V and a couple of amps.
Old 5th August 2007, 05:21 PM   #16
I'm sure they are, I just had visions of lighting desks catching fire.
Old 6th August 2007, 01:25 AM   #17
I tried looking for that stuff,but couldn't manage to find any!
Got any clues as to where I might find some?
Old 6th August 2007, 02:07 AM   #18
nhuwar's Avatar
http://www.gcelectronics.com/order/product_search.asp
Red insulating varnish is the ulitimate in high voltage insulation though and it's made by the same company, GC Electronics.
Hope that helps.
Nick
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88 PTSOUNDLAB Tubes / Valves 30 10th September 2003 07:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
