srpp input stage - Page 2 - diyAudio
Old 31st July 2007, 06:17 PM   #11
nhuwar is offline nhuwar  United States
nhuwar's Avatar
I am using the srpp as starting point I might change it I might not.
Right now Kevinkr is helping me design this amp sence I definantley need the help and he has been gracious enough to help me.
The tube it is driving is a 813 so there is a bit of capacitance there.
Nick
Old 31st July 2007, 11:03 PM   #12
Miles Prower's Avatar
Default Re: Re: Re: srpp input stage
Originally posted by matejS
Miles, can you provide more info on this circuit; I mean, some link explaining it, implementations and some sonic results - at the end this is what really matterrs (not the theory).
You can read more about it Here
Here's the conclusion:
The bootstrapped-compound circuit offered the highest gain and a fairly low output impedance and a much improved PSRR figure. (Definitely a sleeper circuit.)
As for sonics, I'd expect that to be quite good, since the whole purpose behind this is to increase the effective plate load. The closer you can come to a CCS situation, the better the linearity. Improved linearity will tend to make the amp more "transparant" by reducing the extra harmonics.
As for myself, I would prefer to use an actual SRPP in cases where I needed the full push/pull operation. Otherwise, something like what I described, or a Mu Stage or Kimmel might make more sense.
There are no foxes in atheistholes
www.dolphin-hsl.com
SRPP with FETS, what output stage? davidallancole Solid State 18 4th January 2008 06:39 PM
6as7 SRPP output stage Molloy Tubes / Valves 4 15th September 2006 06:39 PM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 06:21 PM
Changing 6DJ8 SRPP stage gain SSassen Tubes / Valves 0 11th April 2006 02:47 PM
Audio Note DAC4 SRPP output stage problems! bbakota2000 Tubes / Valves 5 12th June 2005 01:25 AM
Copyright 1999-2017 diyAudio
