Partridge SE O/P transformers
Old 30th July 2007, 09:42 AM   #1
Stef is offline Stef  United Kingdom
Default Partridge SE O/P transformers
I have been playing with a 300b Thorsten Legacy design using conventional power supply (CLC) with two different output transformers.
The first was a AudioNote AN144 cheepo trx which sounded quite nice and balanced, good in the highs and ok but a bit soft in the bass.
Then I bought some TK4519 potted o/p trx's - the issue I am currently having is that this trx seems to be bloated in the bass and grainy in the treble (been running for 3 weeks now at 8 hrs a day).
Has anyone else used the Partridge o/p trx? Did you get similar results or should I keep on running the unit in and hope for improvements?
I have tried different resistor types and capacitor types to balance the sound but end up with the same bloaty bass and grainy treble - I could of course be doing something wrong?
Any help or suggestions appreciated.
Stef (UK based)
Partridge SE O/P transformersHide this!Advertise here!
Partridge audio output transformer value bentoronto Tubes / Valves 6 15th February 2009 05:36 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
looking for help in transformers. AudioGeek Tubes / Valves 3 17th February 2007 12:36 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 12:38 PM
Partridge Oil Filled C-Core Chokes 1H @ 500mA mozfet Swap Meet 1 28th October 2002 08:27 PM
Copyright ©1999-2017 diyAudio
