| diyAudio Sponsor | ||
I am working on a balanced preamp based on this schematic
![]() For the input, I picked up a pair of Cinemag CMLI-15/15 transformers. I'd like to accept both single ended and balanced inputs, but this being my first endeavor into balanced circuits I am not sure of how to connect everything up. Is it reasonable for balanced input to connect the + and - inputs to the two sides of the primary, and for single ended input to connect the input signal to where the balanced + connects and the input ground to where the balanced - connects? This leaves the balanced ground, but I gather this is often ignored anyway.
http://www.ecpaudio.com |
#2 |
I am confused about how your question is formed so I’ll tell you how I do it. Refer to figure 3 on http://www.raleighaudio.com/active_output.htm
It’s incredibly simple: For balanced input, connect the + signal to the + input and – signal to the – input. For single ended input, connect the signal to the + input and ground to the – input. Switch both sides through your source select switch so you switch +/- for balanced input and +/ground for single ended input. Dave |
#3 |
Thanks Dave. That is what I was trying to say in my own convoluted way. It seemed right, but I wanted to be sure I wasn't missing something.
#4 |
Okay good, I thought so but I wasn't sure.
One more thing: use the chassis ground for the single ended ground. Don’t use the internal circuit ground. Dave |
#5 |
Hello Mr.
For balanced signal use + (hot), - (cold) and ground. On a XLR (Cannon) connector Pin 1 is ground, Pin 2 +(hot) and Pin 3 - (cold). For unbalanced use: (line signal) you have to solder - and ground together otherwise you lose 30 dB of the signal. So the RCA connector would be: center tap + shield - and ground. I have the experience the sound isvery dependant on what transformer you use. In my opinion the best line-trafos ever made was the German Studer (fitted in their two-track reel to reel models), the German Haufe transformers (fitted in Neumann mics etc.), the Swedish Lundahl trafo model SR501 (specially designed for National Swedish Broadcast); and the German Dynacord trafos (fitted in amplifiers like the Eminent and MV-46). Cheers Fredrik |
| PP to balanced input | wicked1 | Tubes / Valves | 7 | 25th February 2009 10:21 PM |
| balanced input stage | sonix | Tubes / Valves | 54 | 5th June 2004 02:47 PM |
| Balanced Input Stage | Bukitoo | Solid State | 5 | 11th March 2004 03:03 AM |
| balanced input problem | Handel | Solid State | 2 | 1st February 2004 03:00 PM |
| [P68] Balanced input??? | Tazzy | Solid State | 9 | 8th February 2003 12:52 PM |
| Page generated in 0.35012 seconds (20.45% PHP - 79.55% MySQL) with 10 queries |
