Sovtek 6C45pi-E bias
Old 31st January 2003, 10:34 PM   #1
Sjef is offline Sjef  Netherlands
Default Sovtek 6C45pi-E bias
Does anyone have any experience with the Sovtek 6C45pi-E tube.
I'm intending to use them in my transformer coupled preamp instead of the Raytheon 5842A and was wondering if anyone had a good advice about the bias operating point.
They wil be used with the existing power supply wich means that, depending on the current drawn, there wil be something btween 160 and 170V on the anode of the tube. The interstage transformer is a 4200/300 Ohm type rated at 30mA DC current.
Old 31st January 2003, 11:03 PM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
All I know (if I remember right) is that their data looks like either both halves of a 6080 in parallel (less dissipation), or a 6336's triode.
If you don't mind even more tubes than a 6AS7-based OTL, it's a good candidate.
Hmm, 4200 ohms sounds a bit high for it, and 300 ohms sounds a bit low.. I guess you're going for distortion or voltage, not power output, eh? (Unless that's the existing tranny and you just wanna reuse it, in which case the low Rp should swamp resonances and such very well. )
Tim
Old 31st January 2003, 11:11 PM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default YO...WAIT A MINUTE.
Tim,I think you're confiding the 45 with the 41.
The 6C45PI is a driver tube while the 6C41 is a regulator.
For inspiration:
PAENG
Frank
Old 31st January 2003, 11:28 PM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
yeah, youre thinking of 6S41S tim :-)
6S45P-E (some people like to muck up the translation from cyr. to latin, and use latin mixed with made up stuff like "pi" damn that irks me.)
its a little 9pin triode, Pa = ~8w IIRC.
its supposed to be pretty close to one of the old WE tubes.. (437A i think? memory is dead here, and im too lazy to look at data of the WE ones..)
http://www.mif.pg.gda.pl/homepages/f...2/6/6S45PE.pdf
Old 31st January 2003, 11:43 PM   #5
fdegrove's Avatar
Default CONFUSING.
Your memory is O.K.
Frank
Old 1st February 2003, 01:11 AM   #6
fdegrove's Avatar
Default ODD FAMILY.
And of course a pic of them both:
Ciao,
Frank
Old 1st February 2003, 02:05 AM   #7
Sch3mat1c's Avatar
Oh yea...thx Colt
BTW he's the one who keeps talking about buying some on ICQ if it weren't for him I would've never posted and confused anyone
Tim
Old 1st February 2003, 08:29 AM   #8
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
6C45P is a stunningly linear valve. It wants >10mA of anode current before it wakes up properly, but can operate with quite low anode voltages (100V). There does tend to be a bit of grid current, so you have to be careful if you take liberties with the (150k max.) grid leak resistor. Because Cag is so high, you can't really use it as a gain stage unless you drive it with a cathode follower (or a moving coil cartridge) unless you don't care/can't measure the HF response. It makes a superb cathode follower, but you need a >100MHz oscilloscope handy to find and tame the oscillation.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 1st February 2003, 05:09 PM   #9
fdegrove's Avatar
Default 6C45
If the datasheets I found are in any way reliable this is also a very low noise valve.
Req 100 Ohm??.
EC8010,you wouldn't be using a MC headamp with valves as I do?
If so I'd be very interested to share scheamtics etc.
Frank
Old 1st February 2003, 06:12 PM   #10
Here's a graph I just pulled out of a russian datasheet
Sovtek 6C45pi-E biasHide this!Advertise here!
preference between 5842 and 6c45pi dsavitsk Tubes / Valves 0 8th December 2006 09:43 PM
6C45Pi data sheet ..translation (?) ashok Everything Else 2 22nd November 2005 09:50 AM
Source for 6c45pi's??? roundel325 Tubes / Valves 4 30th May 2005 09:30 AM
6C45Pi Microphone Preamp MIKET Tubes / Valves 4 2nd May 2004 12:08 AM
6C45PI contant current source MIKET Tubes / Valves 4 1st September 2003 08:44 AM
Copyright ©1999-2017 diyAudio
