diyAudio Sponsor
Old 26th July 2007, 03:21 PM   #1
Default NEWBIE question SET vs. Solid State
I currently have a pair of the Fostex FE208ES recommended BLH enclosures with the FE208ES drivers and the T90A supertweeters. My amplifier is an Adcom GFA-5802 currently. I have heard alot about Tube amps having a much warmer sound and being a better match for high efficiency BLH speakers. Parts Express is running a special on this SET amp below. Would this be a good choice?
http://www.partsexpress.com/pe/showd...number=306-102
Thanks in advance for your advice.
Old 26th July 2007, 06:12 PM   #2
Klimon is offline Klimon  Belgium
Looks fine to me.... Classic choice of tubes and (probably) circuitry which can give you pleasure and some; 7watts also sounds more than okay
Simon
Old 26th July 2007, 06:33 PM   #3
Are you a diy man ? If yes , diy gives you much more pleasure
and if good schematic and components are choosen , i can say more performance too . The critical part the output transformers now are wide available quality and price at the measure of your budget . Now i am in a project for 50w, a single ended 805 triode
valve near the same 999 usd .
Old 26th July 2007, 07:08 PM   #4
It's more than just a "warmer" sound (which may not be true, depending....). Because of the inherent linearity of the tubes and the type of circuits, it's easier to get better clarity and dynamics, especially over transistor circuits that require alot of global negative feedback. I think the transformer coupling also lends a certain smoothness to the sound. It just sounds more natural, which is why I converted to tubes. Once, I even tried a single-ended MOSFET circuit with an output transformer just to see if it was as good as a tube..... Nope!
Old 26th July 2007, 07:18 PM   #5
Thanks everyone. I am a DIY'er but only with building BLH for full range drivers.. The DIY approach to aquiring a tube amp sounds appealing. I do have some background with electron tubes but within the scope of RF for amateur radio. Whatever happened to good old Heathkit? I'll check the newbie thread to see if there is related information.
Andy.
Old 26th July 2007, 07:29 PM   #6
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Hi awhite1159 it sounds like you are half way there with a back ground in amatuer radio.
I also have a back ground in rf but I have to admit audio is a whole diffrent animal but deffinantly do able.
I'm glad you asked the question about those amp's because I have been eying them too.
Good luck
Nick
Old 27th July 2007, 08:25 AM   #7
Some questions and suggestions to help you make your choice:
Do you need an integrated amp (with preamp) or do you have a separate preamp?
How large is your room?
I have a pair of Fostex 208? in a Schmacks BLH. My room is about 7m x 4.5m x 2.5m, with 6.2W of output power I achieve 107 dB SPL at the listening position.
About the amp you mentioned:
The low distortion and high damping factor suggest that negative feedback is used. Looking at the chassis it seems that this amp uses an CRC powersupply filter (no room for chokes).
For DIY have a look here:
TubelabSE
If you do not need a preamp and your budget allows it, have a look at these:
Ladyday signature amp
For some info on loudness and power, have a look at the specs for my amp:
SiTuIT specifications
If you want to go 'all the way' look for a design with DHT's (directly heated triodes) and zero (or adjustable) feedback.
Old 20th August 2007, 01:32 AM   #8
gni is offline gni  United States
gni's Avatar
Decware Zen Amp - Lifetime Warrenty!
Old 20th August 2007, 03:53 AM   #9
Send a message via AIM to ThSpeakerDude88
also www.dynakitparts.com , New exact reproductions of the famous dynaco amps.
always preach the gospel-
and when necessary use words.
Old 20th August 2007, 04:48 AM   #10
frugal-phile(tm)
planet10's Avatar
Witith 7W from an EL34 that is going to be wired as single ended pentode. Means you'll have to go inside to tweak it (ie a switch to be able to run in triode (4W) and someway of adjusting or disabling the feedback),
An SE tube amp is a pretty straight forward diy.
One of the reasons a typical SE yube amp works so well with FR systems like yours is that the high output impedance. This has the amp looking more like a current device so that it puts out more power as the impedance rises -- on a FR giving the FR help where it needs it at the bottom & the top, With a damping factor of 52 this has way to low an output impedance to get this benefit (and means it has a serious amount of feedback -- something a SE tube amp is trying to avoid)
Reading between the lines, i'm guessing this is a tube amp designed for the guys looking for SS-like specs. I'd tend to stay away from it. There are LOTs of other choices pre-built, as kits, or as pre-built kits (like this one, inexpensive Chinese amps just screaming to be modded)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
quick solid state amp question gain Solid State 52 19th November 2008 08:50 AM
Zen v9 questions from a solid state newbie Bas Horneman Pass Labs 3 21st April 2006 01:56 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Page generated in 0.12329 seconds (71.25% PHP - 28.75% MySQL) with 11 queries
