NEWBIE question SET vs. Solid State - Page 5 - diyAudio
Old 13th September 2007, 12:12 AM   #41
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Those hole saws should go right through the diamond plate. It'll chatter a bunch until it hits solid aluminum, so wear ear plugs. It would also be advisable to clamp the plate in place while drilling as the saw could bind and if it starts to spin it could amputate the hand you use to hold your soldering iron.
Old 13th September 2007, 12:37 AM   #42
Tubelab_com's Avatar
As pointed out, I used chassis punches to make the large holes in the diamond plate. I used a real Greenlee for the octal socket holes and the cheap Harbor Freight punches to make the smaller holes. I even used the small punch to make the double holes for the motor run cap. You didn't say how thick your material is. I used .062". The punches may complain if your material is .100".
The octal sockets are about .050 inch above the raised diamonds and the 9 pin is below the deck. This allows a small amount of airflow. My amp is too small, and it gets hot underneath. I have added small feet to allow for airflow and covered the bottom with a heavy wire mesh to keep fingers out. This keeps it cool enough.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 21st September 2007, 10:45 AM   #43
jan.didden's Avatar
Originally posted by lousymusician
My chassis is roughly 1/8" thick aluminum. 1" and 1-1/2" bimetallic hole saws and a drill press made quick work of the tube holes. As Chrish noted, I made oversized holes to assure that there would be a little air flow for cooling. A step drill is nice for the smaller holes, they don't 'grab' the way twist drills can when they punch through the metal.
I used 3/4" standoffs that set the tube sockets a bit below the deck level. I didn't want the white sockets to show below the tubes. All components except the sockets are bottom-mounted, so clearance is not an issue.
Bill
/OT on
Bill, can you please contact me at jan AT linearaudio DOT nl re: Burning Amp Festival,
Thanks, Jan Didden
/OT off
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
quick solid state amp question gain Solid State 52 19th November 2008 08:50 AM
Zen v9 questions from a solid state newbie Bas Horneman Pass Labs 3 21st April 2006 01:56 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Copyright 1999-2017 diyAudio
