6N6P cascode + 6AS7 Cathode follower
Old 27th July 2007, 01:31 PM   #11
croccodillo is offline croccodillo  Italy
croccodillo's Avatar
Crocodillo: IS the CCS with low mu output the same as a mu-follower?
I call it in that way but it is not correct, actually.
The CCS is made in a way that it keeps the current flowing through the tube constant, while delivering a variable current to the load.
THIS is the schematic.
Note that I already tried it (with different values and different transistors), and it works flawlessy.
Being the current through R2 constant, we have no signal across it (its voltage is always constant).
The only BIG drawback is that it needs a floating supply; my idea for the amplifier is to use two really small PCB transformers (about 2-3W) powered directly from the main.
Ciao,
Giovanni
In Nomine Libertatis Vincula Edificamus,
In Nomine Veritatis Mendacia Efferimus.
Old 28th July 2007, 06:24 AM   #12
schiller is offline schiller  Greece
Default Reduce current, increase voltage
Hi, according to the 6N6 datasheet, 160V/20mA will deliver max.
200Vp-p as you suggested.
220-250V Ua-k across the upper tube and 10-12mA will do the job. I haven't tried it with 6N6, but with the 5687 which is similar, it gives more than 300Vp-p with less than 3% 2nd harmonic (choke load, must be the same with CCS).
Greetings
Konstantinos
Old 15th September 2007, 09:33 AM   #13
cjng74 is offline cjng74  Malaysia
can anyone share the characteristic graph of 6AS7G or 6080?
the current graph only limit to B+ of 200 or below.
thanks.
CJ
6N6P cascode + 6AS7 Cathode followerHide this!Advertise here!
cascode vs asymmetrical cathode coupled oldeurope Tubes / Valves 47 18th April 2008 04:37 PM
6N6P cascode calculation croccodillo Tubes / Valves 2 11th September 2007 04:56 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Cathode Follower? Yay or nay? SHiFTY Tubes / Valves 25 16th March 2004 06:38 AM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 09:49 PM
