Help me calculator OPT for 807, 6C4C tubes.
Old 26th July 2007, 06:50 AM   #1
invalid is offline invalid  Viet Nam
Default Help me calculator OPT for 807, 6C4C tubes.
I want DIY OPT for 807 Tube, but I can't calculator number turn, wire size,....
I have FE 32, dim 4cm.
Zin range 2,5k to 6k.
Zout is 4Ohm, 8Ohm.
Please help me. In future, I use 6C4C tube.
Old 26th July 2007, 04:14 PM   #2
Yvesm is offline Yvesm  France
Yvesm's Avatar
This should help:
http://www.dissident-audio.com/OPT_da/Page.html
Yves.
Old 31st July 2007, 12:41 AM   #3
Thanks very much.
You can give me diagram for it? I have Fe 32, but I don't find this in list.
ex: I want OPT is:
Zin=3100 Ohm
Zout=8 Ohm.
Consequently: Sec turn? Pri turn? and turn in sesion.
Old 31st July 2007, 06:32 AM   #4
Yvesm's Avatar
Hi ,
What is FE32 ?
Gimme some physical data or a sketch.
Yves.
Old 31st July 2007, 07:57 AM   #5
cerrem is offline cerrem  United States
cerrem's Avatar
WHat operating conditions, voltages are you using on the 807??
Is this TRIODE wired???
Chris
Old 31st July 2007, 09:25 AM   #6
Sorry for my English.
This is my Fe:
Old 31st July 2007, 09:25 AM   #7
This is my Fe:
Old 31st July 2007, 09:25 AM   #8
and my Scheme, sorry, I don't have scheme image, I draw by WORD.
Old 31st July 2007, 04:25 PM   #9
Yvesm's Avatar
Your iron size is very close to the "european" EI96B.
You could start this way.
Yves.
Old 1st August 2007, 12:49 AM   #10
Thanks very much. If I want change values Zin to 3100 Ohm then power is decrease. But I can use for 6C4C or 6L6 in the future, It's correct?
Help me calculator OPT for 807, 6C4C tubes.Hide this!Advertise here!
Sound quality of 6C4C is same with 2A3? noyan Tubes / Valves 10 17th June 2005 02:18 AM
Copyright ©1999-2017 diyAudio
