| diyAudio Sponsor | ||
#81 |
I built a CF output amp once.
From memory, first stage 6sn7 (I think I might have had two stages), 6B4G with LL1677 driving PP 6550. No global NFB. I used Dynaco Mark IV iron. It sounded better than anything I ever heard. |
#82 |
It's not 20 watts but at the moment I'm listening to a CF parafeed headphone amp based around a single compactron that'll swing 11 volts p-p into a pair of 60 ohms headphones and sounds wonderful. The only gotcha is it takes a lot of current to keep HF distortion in the ballpark of LF distortion due to the CF's asymetrical slew rates.
Ears aren't microphones. |
#83 |
Did you gentlemen try such tubes like IRFP27N60K, or similar?
Sound awesome despite of huge and very variable capacitances!
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#84 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#85 | |
A mosfet follower with a low ratio OPT and a tube input stage would be very interesting. Anyway, cathode follower obviously has certain qualities as output stages. I have a pair of 3,5k/8 15W OPTs that I bought for the 808 project, now IŽm getting curious how these would perform wired as 1,75k/8 driven by PL519 followers. The transformers sounded quite good when i tried them in a tiny spud amp last weekend and they would probably sound even better with properly sized output tubes. Gah, so many projects, so little time... |
#86 | |
#87 | |||
I switched to them after experimenting with tube cathode followers. By the way, even ordinary power transformers sounded nice with cathode followers, auto-transformers even better, especially when the follower is loaded by CCS. A first, I used a MOSFET as a CCS. Then, I used it instead of a cathode follower. After that I replaced a CCS by a voltage to current converter made of pair of BJT's. That breadboard scared me when a water run on a record suddenly. I've jumped and turned around before realizing that there can't be a waterfall in my room... Quote:
...and absolutely valid one!
#88 | ||
Until then, the idea of a PL519 CF amp with my existing 3,5k (miswired to 1,75k) OPTs seems more and more appealing. If done right it could be very minimalistic: Quote:
#89 | |
#90 | |
this amp would require, IŽm more likely on my own road to...hell. IŽve been lucky with HV supplies so far, but I guess that when I finally get zapped it will be from a PSU capable of turning me into 300 pounds of roast beef in 3 seconds... |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 07:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 03:12 PM |
| Cathode Follower? Yay or nay? | SHiFTY | Tubes / Valves | 25 | 16th March 2004 06:38 AM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 09:49 PM |
| Page generated in 0.13458 seconds (61.79% PHP - 38.21% MySQL) with 11 queries |
