| diyAudio Sponsor | ||
#21 |
It works. Some twiddling with all of the knobs, and I get a nice sine wave on the scope. I tried tube current from 80 mA to 200 mA, and I tried several combinations of load impedances. The best results happen with a 4 ohm load on the 16 ohm tap on the transformer. That should work out to a 750 ohm load on the tube. The little UBT-3 transformer didn't like this too much, and I figure that I was loosing several watts in the OPT.
Power at the onset of clipping was 9.1 watts. The distortion is related to tube current. At 5 watts output I get 4.8% distortion with 80 mA of tube current. At 150 mA the distortion drops to 1.6% and at 200 mA the distortion is 1.1%. The output impedance is under 1 ohm, which is mostly OPT losses. The voltage drop on the primary was not nearly as severe as the secondary when switching from an 8 ohm load to a 4 ohm load. I listened to it (in glorious mono) for most of the afternoon with both of my "8 OHM" speakers in parallel on the 16 ohm tap. The sound is awesome, solid bass, crystal clear highs....... I found that 80 mA sounded just as good at 200 mA except for some bass heavy music (Pink Floyd).
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#22 |
I suppose someone is going to ask for a schematic, so here it is. Before anyone rushes out to build this, let me explain a few things.
The driver is pretty straight forward. The input tube is the high mu section of a 6EM7. Just about any tube with enough gain will work here. Adjust the load resistor and tube current to match your choice. The second stage requires a tube that can operate linearly at low plate voltages, and not explode as the plate voltage swings up to the supply voltage. The sweep tubes made for vertical (frame) output duty work well here, so this is why I chose the 6EM7. A 6DR7 (9 pin) will work well also. The CCS load is the key to developing a lot of voltage swing. A choke load should work also, but good chokes are not cheap and the CCS chips are. The output section requires some thought. I used a 6LW6 sweep tube because I know how much abuse they can take without issue. The screen grid rating is 275 volts, I ran it all day at 550 volts. The plate dissipation rating is 40 watts, I had it at 80 watts for about 2 hours, and up to 100 watts for brief testing. At 80 watts there is no hint of plate or screen grid glow. At 100 watts the plate gets a dull red glow after about 2 minutes. You need to choose a tube (or parallel combination) that can take this for extended time periods, you also need to plan the chassis for some heat dissipation. Am I going to build one of these? Yes! First, I need to find a bigger OPT. Then, I plan to do some further testing. See those empty sockets, I plan to fill them up! I haven't decided which tubes yet, or just how much power it will make. I probably will settle for a reasonably powered SE cathode follower, but I plan to build an insanely powerful P-P cathode follower if all of my other circuitry works out. I will do more testing on this circuit, and post updates as I find out anything useful.
#23 |
Hello
The disign off your 6lw6 amplifier his very interresting. Problem : I'm supposed it 'll be difficult to find this valves in France. It's easyer to find EL 504 EL 509 and EL519 or 6C33 I don't know "Audio Reality" bookand Bruce Rozenblitts disign 3x KT88 Someone can tell me more about this disign. Thanks yan |
#24 |
I´ve been thinking about building something like this for quite some time now. Possible tube candidates would be PL519 (perhaps more than one per channel) and a choke loaded 12B4A as driver stage.
With a few low Rp output tubes in // we could get away with a very low turns ratio in the OTP, possibly an autoformer if we can live with a fraction of a volt DC across the speakers. I took this concept to its extremes in my latest project; 4xPL504 per channel working as cathode followers with only a ~0,5H choke as load, ie SE OTL. Sound is VERY good with the right speakers. Connecting the speakers to (imagined) centre taps on the chokes would change the load seen by the tubes and probably increase output power and the damping factor big time, but then it wouldn´t be OTL anymore...:/ By the way, PP cathode followers would work great with autoformers in the output stage since the DC offset would cancel. |
#25 |
Well, since I´m going to build an amp with 6AV5GA (Sylvania)soon perhaps this topology would be the way to go?
I will be using Hammond 125DSE output transformers, let´s say I wire them as 2,5K/8R with the secondary in series with the primary (auroformer) and feed the output tubes with about 250V plate-cathode and draw 70mA through the whole thing. Together with a driver stage that can can deliver all the required voltage swing this should be up for 3-4 good sounding watts, maybe more. Accordning to Sylvanias datasheet 6AV5GA can handle +-200V peak heater-cathode, so I think it would be possible to feed both channels from one heater winding which is referenced to ground. Tubelab, I bet you have one or two things to say about this Cheers, Daniel |
#26 |
Audio reality was a paperback book sold by Bruce Rosenblitt at Transcendent Sound several years ago. He now sells it in PDF format. The book has been reviewed several times on the internet. Some reviews are highly positive, while some are extremely negative. The material has a current copyroght, so I can not post the schematic. A "simplified" version can be found in this (positive) review:
http://www.tubecad.com/november99/page10.html The opposite opinion can be found here: http://www.enjoythemusic.com/magazin...dioreality.htm I bought the paperback book about 7 years ago, but I have not built any of the circuits. Maybe its the engineer in me, but I wasn't impressed with them. Some of his OTL amplifiers have received good reviews in the audio press. When I set out to build last Saturdays experiment, I reached for my trusty old 6AV5, and thought about what I was going to do. I was planning to (and I did) explore the upper end of the power spectrum, so I put bach the 6AV5, and grabbed a 6LW6. These things laugh at power levels that would melt a 6AV5, I was running one tube at 190 mA and 525 volts. That is about 100 watts of dissipation. This experiment proved that the concept is viable and that the 6lw6 is almost indestructable. After looking over the test data, it seems that I was loosing about half of my power in the mismatched OPT. I need to experiment with a choke, and a resistive load bank. These experiments will probably have to wait until I get back from a trip next week.
#27 | |
No, a power cathode follower with DH tubes that draws 10V 5A each of the filaments and requires about +-1kV of swing would be practically impossible. First on the list will be to locate a pair of reasonably priced plate chokes for the drivers, I think vt4c.com has some interesting stuff. |
#28 | ||
From the Tube CAD review, I picked up this error:
The higher the gain, even if used in a low gain application, the more independent of the device characteristics the circuit performance becomes. So you won't find the sand heads doing things like swapping out transistors, not because it's more difficult than simply pulling a tube out of a socket, but because it doesn't really make any difference. VTs, being the low gain devices they are, circuit performance is more dependent on device characteristics as well as topology. You may get a different sound by trying different VTs, especially if NFB isn't involved. Then there's this bit of self promotion: Quote:
Of course, you can patent anything, but I doubt this would stand up under a legal challenge. It's prior art. When I see schtuffs like that, I get a little bit suspicious. When I see Blackie Pagano complaining endlessly about how Rosenblit writes, and not addressing what he writes, I get a whole bunch of suspicious. Hellzamatter Blackie, Rosenblit didn't slip you a little $omething under the table? |
#29 |
I got this book when it first came out, and actually agree with SOME of what he says. He spends quite a few pages slamming the $300 power cord - magic stone - silver wired - titanium interconnect crowd. The second half of the book has his version of "correct engineering" complete with circuit diagrams. I don't agree with the designs exactly myself, but they did get me thinking about how I would do them differently.
The book does have an amplifier with a cathode follower output stage. The version in the book that I have uses 3 X 6550 in parallel. There is 5 pages of explanations about the design and theory some of whic does conflict with the text just a page before. There is a whole bunch of text devoted to designing for a low output impedance, which turned out to be 2.8 ohms, so 10 db of feedback was added. A cathode follower should be capable of better than 2.8 ohms without feedback. I don't understand why you need a cathode follower to drive a cathode follower. A properly designed cathode follower should have a high input impedance, and it should be nearly impossible to draw grid current. What is required for these conditions to be met. Bruce points out that an output tube (or tubes) capable of enough peak current capability to drive a reactive load is required. He chooses 3 X 250 mA. Good, but I am looking for AMPS of peak current capability. This insures that the cathode is capable of going where the grid sends it. Then you need a lot of transconductance to be sure that the grid is capable of sending the cathode where it needs to go. If these conditions are met, then the driver determines the sound character of the amp. The cathode follower merely pumps up the current capability of the driver stage. I am still evaluating output stages, but a single 6LW6 has a 1.4 amp peak plate current rating. A 6336A (both sections) 800 mA with a transconductance of 26000. There are others that will work also. I believe that the driver should be a circuit that you would listen to by itself as an SE amp. It should be optimized for maximum voltage swing. This usually means fixed bias. The circuit that I posted previously does pretty good, but I am sure that there are others that work well also. I plan to optimize this cathode follower thing to death over the next few months. I have some rather unusual operating conditions, but most of what I am doing will be applicable to a standard amp. I am leaving on a 2500 mile trip this weekend, so no new experiments will occur.
#30 | |||
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 08:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 04:12 PM |
| Cathode Follower? Yay or nay? | SHiFTY | Tubes / Valves | 25 | 16th March 2004 07:38 AM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 10:49 PM |
| Page generated in 0.17574 seconds (84.97% PHP - 15.03% MySQL) with 11 queries |
