| diyAudio Sponsor | ||
#121 |
Found this huge toroid for ~20 bucks on Tradera (Ebay, sort of):
800VA with 230 + 33 + 2x11,7v secondaries. Current rating of each winding is unknown but judging by the wire gauge it should be more than enough for output stage B+ and heaters. 300VDC is a bit on the high side for my application but with >60V dropped across the cathode resistors it might turn out just right. With this beast in the power supply and the 120W-rated 1650T output transformers it would really be a shame not to use 4 x PL519 per channel and get 50-60W class A...! |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 08:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 04:12 PM |
| Cathode Follower? Yay or nay? | SHiFTY | Tubes / Valves | 25 | 16th March 2004 07:38 AM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 10:49 PM |
| Page generated in 0.05823 seconds (65.73% PHP - 34.27% MySQL) with 11 queries |
