from Shoog
I would very much like to see that too...
from zarniwoop
Please do - I am curious about the 'back-to'back' trafos you mention
from Jeb-D
Yes, they are They were what was dug from the bin. They seem to work, but I am surre Thorsten would upbraid my use of electrolytics for B+ decoupling
from Shoog
I have a variation of the basic KYW design that uses CCS to load the plates on the 2nd stage (6DJ8). Is that where you have installed yours?
from fred76
Exactly! (although I'm not sure that the 10nF mica's are Russian or not). In any case, they are fugitives from my parts bin. I intend to order some 'proper' caps from Solen now that I know the cct works.
Jess
Arnold - Any ideas where we might find the revised circuit.
from zarniwoop
maybe a $50 project. i'll have to post a schematic
from Jeb-D
Those are some pretty serious caps your using
from Shoog
Theres definately a tightening of the overall presentation
from fred76
Are those 10nF caps Russian Mica, and the 1nF pair radial polystyrene?
Jess
Yes thats where I have mine.
On further listening I have a slight feeling that the bass is a bit more recessed than it was. I don't know how that might have come about because the input impedance of the ECC88 should remain the same I think. Could be because my rail voltage has sagged a bit.
Shoog
You did it yourself so ofcourse it is special. So post itIf anyone wants the artwork, I could post it, but I don't think it is anything special.
And since I just upgraded my turntable at least I will be intrested
So post it
OK, here it is...
Cheers
Jess
Shoog said:Arnold,
Shoog
Shoog, I found it in my offline files, and it's called Thorsten's Not so simple phono stage.
from arnoldc
I did a search throughout the forum and couldn't find it - would you mind posting a link or maybe the schematic?
Jess
Jess
How about also a CCS on the first stage too? Would it be made the sound even better?
It would alter the RIAA curve tracking as the load is part of the network. The Not so simple phono stage addresses these problems.
Shoog
JesseG said:
from fred76
Jess
Thanks, I think you already have good Eq caps. Try to bypass the decoupling Aerovox lytics with some cheap 1uF/400VDC (or any small value) polyesters and see if the highs smoothen out.
A good CCS at the top of the ECC88 might help the bass part. Another alt are plate chokes but it would cost more and require more space and placement consideration.
- Tubes / Valves
- IT WORKS! Tube Phono Stage
