| diyAudio Sponsor | ||
Dear group,
I have made the most startling discovery! I've built an entire amp where no connections are made to any of the tubes! It works beautifully. As I predicted, all prior theory on tubes was incorrect! They don't need to be biased, or have voltages applied to them, or even be in sockets!!!! I really am smarter than all those dumb RCA engineers. My research shows quite clearly that bias, coupling, the behavior of capacitors, and current flow are all myths. note: I may do an upgrade later on and scotch tape the tubes to the bottom of the box, because they do roll around quite a bit... Cheers! No grid connection |
| c3g connections | garbage | Tubes / Valves | 8 | 16th October 2010 09:51 AM |
| BNC connections... | Stormrider | Parts | 2 | 22nd June 2008 08:24 PM |
| What are XLR connections?? | JuNA | Pass Labs | 30 | 24th November 2005 07:47 AM |
| HELP with connections | Tony.ca | Multi-Way | 7 | 24th May 2005 12:56 AM |
| Page generated in 0.06622 seconds (67.20% PHP - 32.80% MySQL) with 10 queries |
