| diyAudio Sponsor | ||
I have convinced my brother he needs to get a tube amp, after hearing my completed Kennedy Audio / ST70.
I have a full set of iron from a ST70, the A-470 output xfrms and PA-060 power tranny. So, I'd like to build something within these constraints, and the following other preferences: 1. Readily available tubes in plentious supply and affordable. I currently use the 12AX7 into a 12AU7 LTP into EL34. All JJ tubes, and I'm happy with the results. I've also heard a lot of good things about the 6n6p, 6sn7, and ECC99. 2. Would like to avoid the 6922 and its variants; had bad JUJU with RF oscillations. Yeah, it was likely the builder, but if I'm building for someone else, I don't want too much troubleshooting. 3. No DHT's. This will be reserved for my personal use. 4. Build will be with non-exotic parts. ST70 iron really isn't worth much more than $5 coupling caps, IMO. However, I will be avoiding electrolytic caps in the PS. 5. I like the IXYS 10M45S current source; have had good results in the LTP, and I have a bunch. 6. Triode or UL really doesn't matter; if anything, I might make incorporate a switch. 7. If it matters, there will be a 80 Hz 6dB LP filter on the input, so I don't require thunderous bass out of the OPT's. 8. Input sensitivity maybe around a volt. 9. Speakers: actually don't know at this time, but it won't be horns, I can tell you that much. Most likely a simple 6" MTM. 15W will be more than enough, and if quality, 10W is okay, too. 10. SS rectification. Sure, I can build the exact same thing, but that's not exactly the most fun, either. A little variation is good for the soul. But again, nothing experimental or ultra-daring. Thanks for the suggestions. |
#2 |
Hi Zigzagflux,
I am not sure that I am qualified to comment as I am new to this myself, however - I had very similar ideas when I started my project and decided to go with a modified ST70. Why not make a version of the ST70 with your own chassis. It seems to meet most of your criteria. You can upgrade the power supply caps (there is a kit if you like from triodelectronics) and point to point wire the rest. As far as the solid state rectification goes, the cap board kit has a solid state option or you could replace the GZ34 with a solid state version of this tube. I believe that a plug in solid state version of the GZ34 is available from radiodaze. There is also a version of the preamp (I think triode has this as well) replacing the 7199's with EF86 tubes. I believe there is also a 12AX7 version around somewhere as well. Just a thought, cheers, Rob |
#3 | |
Sorry, I should have mentioned that. I have no chassis, no other parts, just the iron. So, yes, I will be building everything else from scratch. It surely won't look anything like a ST70. In that respect, sky's the limit, as I have no real physical constraints. |
#4 |
Dude,
Let's look at the PSU 1st. SS rectifying the PA-060's B+ winding is going to yield a high rail voltage. The extra Volts present an opportunity. Original ST70 power trafos are somewhat undersized. Ease the strain on the trafo by CLC filtering the B+ using 10 muF. in the 1st position followed by a Hammond 193M (10 H./300 mA.) choke. The smallish 1st cap. yields a large conduction angle and a cooler trafo. The large inductance takes a BITE out of the ripple and isolates the trafo from the remainder of the filter. BTW, a 'lytic is fine for the 10 muF. part, as it is not in the signal path. The B+ rail can be soft started by placing a CL150 NTC inrush current limiter between the diodes and the filter. Series connected pairs of UF4007s will rectify the B+. A RRSF will be used to keep SS diode switching noise out of the power trafo. With all of the above, B+ still rates to be on the high side. Combination bias using a shared RC network in each channel under the EL34 cathodes consumes the remaining extra Volts. Combination bias allows the use of a single bias set pot. per channel and stabilizes the tubes against runaway. The 5 VAC rectifier filament winding can be voltage multiplied to yield a negative rail that can power the LTP current sink and provide EL34 bias. The OEM bias tap gets tied off. The 2nd schematic here will do nicely. As drawn, a positive rail is created. Stand everything on its head for a negative rail. Use "noiseless" Schottky diodes in the multiplier.
Eli D. |
#5 |
Okay.
So you are proposing a two stage amp (LTP as the first stage, cap coupled directly to the EL34). Otherwise, we wouldn't need the negative rail for the LTP, right? And is the EL34 the best choice? (No doubt, given availability and cost). I'll be using PSUD for the power supply design. In fact, I had selected a 10uF followed by 4H to a 40uF cap, yielding 425V with 800mV AC ripple. I have no problem cranking up the L if necessary, though. I won't be using the C-354 choke. Tangent: PSUD is a fantastic program, and doggone accurate if you get the transformer modeled right. Forgive me, but what's RRSF? Reverse Recovery Soft Freugenschlager? No problem with the rest of the power supply. Next? |
#6 | ||||
BTW, since it's outside the NFB loop, a PIO cap. between the 6SN7 section and the LTP rates to be audible and might be beneficial. Oh yeah, 150 Ohms and 220 muF. seem to be reasonable values for the EL34 bias networks.
Eli D. |
#7 | |
That said, if it were my amp, I'd still do something with two stages like you said.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 |
So here's my first iteration. Kind of took advice from both of you. If I can get the two stage amp to work, that would be the ticket.
I am working the 6AQ4 fairly hard at 210V, 6 mA, but that seemed to be the most linear range from the curves. If you have experience that says otherwise, let me know. Chose the load to be about twice the Rp. I calculate an LTP gain around 46 with Zout of 8K. Input Z of EL34 is around 120pF, I think, so my F3 points are 3Hz and in excess of 100KHz. A little stumped by the common cathode R for the output stage. I calculate 100mA total with about -30V of Vgk, so that comes to 300 ohms, not 150. Eli, you also mentioned using the negative rail for EL34 bias; are you proposing a combination of fixed and cathode bias? Fundamentally, if I'm developing a negative rail for the LTP anyway, it would seem fixed bias to be the bees knees for the output stage. Unless you're adding the cathode R strictly for additional stabilization? So far, so good? |
#9 |
The diff amp looks fine. I measured the 6AQ4 at a few different currents between 1 and 10mA, and it did well at all of them.
You might consider making the CCS variable and use it to experiment with a few different operating points.
#10 | ||
Eli D. |
| The Humble Soldering Iron (Recommendations) | GlidingDutchman | Equipment & Tools | 40 | 21st September 2008 01:05 PM |
| DIY Dynaco ST70 | wingking3000 | Tubes / Valves | 2 | 25th July 2008 10:20 PM |
| Need help with my ST70 | JayH3 | Tubes / Valves | 7 | 23rd May 2008 12:56 AM |
| Any recommendations for Soldering Iron | hotscot | Parts | 23 | 23rd February 2006 12:53 AM |
| Page generated in 0.15604 seconds (87.62% PHP - 12.38% MySQL) with 11 queries |
