Thorsten's Chokeless Monkey 2a3 - diyAudio
Old 31st January 2003, 06:29 AM   #1
Serow is offline Serow  Canada
Default Thorsten's Chokeless Monkey 2a3
I've been trying to understand the details of Thorsten's design as posted in Joelist:
>right. as i alluded to on wedneday. using the cathode for B+.
Yup, and to supply the Screen Grid via a Voltage Divider, also adding full
DC Feedback to the circuit.....
>however, the choke inductance requirement is a tough one.
>seems you'd need several hundred henries.
This Monkey is a "Chokeless Monkey".... The penthode likes to see a LOW
impedance load, not a high Impedance one for best linearity.... So, with one
of my favourite EL84 Operating Points as Voltage Amp we get:
Va 190V (total +B must be raised to 490V here)
Vg2 100V
Ia 12mA
Anode Load 3k9
So, 3K9 from Cathode to Grid of the 2A3, the EL84 Anode gets connected to
the 2A3 Grid.....
The 2A3 Cathode will be at 235V, so a Voltage Divider for the Screen runs of
the Cathode of the 2A3. I'd like to have a reasonable DC impedance here, so
we'll draw another 12mA there (about 2mA of which go into the screen). The
Lower Resistor will be 10k, the Upper (to the Cathode of the 2A3) around
11k. From G2 we take a 22uF Cap to the EL84 Cathode.
Now, the resistors from the G2 Voltage Divider, the additional appx. 6K8 2A3
Cathode Resistor and the G2 Bypass Cap meet at the EL84 Cathode, the
resistor from there to ground Biases the Valve at about 3 - 4V (needs to be
determined), so around 100 Ohm Adjustable will do. Again, the Cathode
Resistor will not be bypassed....
Voila, a Driverstage with very low Drive Impedance, pleanty of gain and
linearity. Only Class A2 Swing is a no-no....
Still, this one with an EL84 and a 2A3 (or 45 with recalculated Resistors)
will give a great and cheap amp....
Rather amazing all this Monkey-Business, isn't it....
Later T
__________________________________________________ ______________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
Date: Fri, 09 Jun 2000 14:36:24 GMT
Old 31st January 2003, 06:30 AM   #2
Here's the schematic I drew from the description:
Old 31st January 2003, 06:33 AM   #3
Isn't 23 mA pretty low current for a 2a3? The similar 45 amp he posted earlier is run at 34 mA.
Thorsten mentions something about a 6K8 anode resistor for the 2a3, after describing it as 11K earlier. Perhaps this causes my confusion.
Thanks for your help.
Eric Sampson
Old 31st January 2003, 01:57 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Eric,
Why don't you ask him?
His ID is an open secret...
http://www.diyaudio.com/forums/membe...fo&userid=3984
Old 31st January 2003, 05:10 PM   #5
Previously: Kuei Yang Wang
Default Re: Thorsten's Chokeless Monkey 2a3
The 6K8 Resistor is in ADDITION to the 11k and 10k Resistor. At the appx. 230V across it a further 34mA are drawn, giving us a total of 58mA current. The rest looks fine, except the 4k3 OPT.
Ciao T
Old 31st January 2003, 05:18 PM   #6
Default Huh?
sign off above:
Ciao T???
CRyder
Ryder
Any fool can ask more questions than seven sages can answer.
Old 31st January 2003, 05:21 PM   #7
diyAudio Senior Member
fdegrove's Avatar
Default T.
Craig,
T. stands for Torsten.
Ciao,
F.
Frank
Old 31st January 2003, 05:27 PM   #8
Hi Frank.
Ya..You mean Thorsten. I got that part.
Is KYW TL incognito or something? That is how T always signs off. I don't get the sign off.
Cheers
CRyder
Ryder
Old 31st January 2003, 05:29 PM   #9
dhaen's Avatar
Craig,
Originally posted by dhaen
Eric,
http://www.diyaudio.com/forums/membe...mp;userid=3984
Old 31st January 2003, 05:29 PM   #10
fdegrove's Avatar
Default THORSTEN.
Hi Craig,
The other one and only,yes.
Frank
A choked Monkey, please! Fuling Tubes / Valves 40 13th May 2003 07:57 PM
Chokeless monkey Bas Horneman Tubes / Valves 14 13th May 2003 11:21 AM
Copyright 1999-2017 diyAudio
