diyAudio Sponsor
Old 21st July 2007, 10:20 PM   #1
Sal Brisindi's Avatar
Default Using a ignition coil for a audio transformer
Hmmm,
I wonder how this would sound....
http://www.allaboutcircuits.com/vol_6/chpt_5/19.html
Sal
Old 21st July 2007, 10:59 PM   #2
Would probably go well with that turntable with a bearing based on a Harley inlet valve...
Old 22nd July 2007, 12:03 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
There has been a thread abour this
Old 22nd July 2007, 12:39 AM   #4
Naughty boy!
Altmann DIY TT here. The man built what appears to be a satisfactory mass damped basing system. For somebody with the necessary power wood and metal working equipment, that just might be a good project. Drill 12 pockets around the periphery of the platter and fill them with Lead. An acrylic sheet as the top layer of the platter and a good clamp should finish things off nicely.
Eli D.
Old 22nd July 2007, 12:54 AM   #5
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
Caution, the speaker leads will carry anode voltage in this circuit.
/ Anders
Old 22nd July 2007, 02:34 AM   #6
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Ignition coils are flyback transformers which work as a coupled inductor. I'm not sure if that is an ideal characteristic for output transformers. Sure it may work, but better than transformers designed for audio?... probably not.
Old 22nd July 2007, 03:29 PM   #7
You can buy an inexpensive OPT for less than you would normally spend for a new ignition coil (junkyard parts are cheaper obviously).
So the rationale for using the ignition coil has pretty much gone away, and the high voltage on the speaker leads hazard would deter me from recommending it.
Old 22nd July 2007, 04:09 PM   #8
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
It is easy to re-arrange the connections to the coil !!
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 22nd July 2007, 05:04 PM   #9
Andy
But it is not possible to isolate the "primary" and "secondary" windings like a real OPT does, and if you are going to redesign the circuit you might as well eliminate the coil/autoformer anyway.
You can buy a real OPT for under $20 US, and a coil will as much or more unless you can get one from a junkyard.
Old 24th July 2007, 03:36 AM   #10
Send a message via AIM to ThSpeakerDude88
not necessarily.. a few of my neighbors have boxes full of old ignition coils .. I guess its for people who know people like that to fiddle with. It is ashame that an ignition coil doesn't have another secondary, as it could be used as a parafeed opt with the primay having the choke integrated.
always preach the gospel-
and when necessary use words.
Ignition Coil Toobe Amplifier Mark A. Gulbrandsen Tubes / Valves 13 31st January 2007 06:48 PM
How to coil a transformer hongv Class D 6 5th September 2005 09:13 AM
Transformer and Coil for sale. pixie Swap Meet 2 7th March 2001 07:34 PM
Page generated in 0.10298 seconds (81.46% PHP - 18.54% MySQL) with 10 queries
