#341 | |
#342 | |
diyAudio Moderator Emeritus
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#343 |
I have an aquaintance who claims to have been electrocuted on several occasions.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
#344 |
I once saw a headline in a local paper that said: "Electrocuted man dies".
#345 | |
Are you sure he doesn't believe in reincarnation? This thread just won't die, will it... |
#346 | |
#347 |
Speakerholic
And for some reason, we still have the second comma in the title. Mind you the title says nothing about punctuation so...
If words add meaning to expression then write on! CW Sept 07 |
#348 | |
frugal-phile(tm)
dave oops... an on topic post (hope it doesn't head off to texas )
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#349 |
They are serial commas. Without the second comma, it would suggest that spelling was comprised of capitalization and grammar.
-e |
#350 |
Speakerholic
I don't think so. The comma is redundant regardless of the number of subjects. I have never used a comma in that location and haven't been corrected on it.
Edit: I just checked with punctation check and it appears my assumptions are correct. 2nd edit: I was answering Dave's question but I guess it still applies. |
| Responce - spelling rant | joe carrow | Everything Else | 73 | 26th May 2007 01:57 PM |
| Defiant spelling... | runebivrin | The Lounge | 64 | 9th March 2005 06:34 AM |
| Audiobauhn (Spelling?) Question | OMNIFEX | Multi-Way | 11 | 5th January 2004 04:19 AM |
