diyAudio Sponsor
Old 20th July 2007, 09:32 AM   #1
redrabbit's Avatar
Default Multi Section Cap....diy?
My old Hallicrafters multiband receiver (S-40A) ......the only thing it does now, is make a wonderfully loud hum/tone....sounds like 60 kHZ.
I am assuming it is the multi section cap , gone bad.
30-10-10 @ 450v
Can I build my own with separate caps ??
Do all the neg terminals go together, and the positives go to the circuit?
=RR=
Old 20th July 2007, 09:37 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Damn, good ears if you can hear 50kHz...
Yeah, seperate caps are fine..
Old 20th July 2007, 04:26 PM   #3
nhuwar is offline nhuwar  United States
nhuwar's Avatar
You want the negative lead of one cap to the positive lead of the other cap you want in series with it.
Nick
Old 20th July 2007, 04:58 PM   #4
kevinkr's Avatar
Nick
Use 450V caps and all negative leads get tied together, no caps in series. Better still order a similar valued replacement from AES at www.tubesandmore.com to keep it looking original. You can use 40/20/20 or 30/20/20 common values currently available.
I have restored a bunch of vintage sw/ham band sets in the past.
(Lately Atwater Kent 310)
Kevin
www.kta-hifi.net
Old 20th July 2007, 06:02 PM   #5
nhuwar's Avatar
Ops! I stand corrected Thanks Kevin
Replacing multi-section caps with multiple caps? Sir Trefor Tubes / Valves 1 29th May 2007 11:17 PM
ono mc section giolight Pass Labs 7 23rd December 2003 12:14 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 06:54 PM
Page generated in 0.09672 seconds (71.25% PHP - 28.75% MySQL) with 10 queries
