| diyAudio Sponsor | ||
Hi all,
I try to use 25z6 as tube rectifier but it's can work under 75 ma per plate.What is a double diode tube for working around 125 mA per Plate ? Many thanks,
PapaNohn |
#2 |
EYY13 for max. 250 mA (usable as a voltage doubler), for half-wave 5T4, 5Z4, 5V4...
Regards Andreas |
#3 |
Take a look at the 6BY5G/GA.. Watch the input capacitor value with this tube though.
www.kta-hifi.net |
#4 | |
8uf C-input is O.K. Regards,
PapaNohn |
| NOS russian rectifier tubes | Vladi59 | Swap Meet | 0 | 2nd August 2009 11:44 AM |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| Rectifier Tubes | denny9167 | Tubes / Valves | 10 | 21st April 2008 06:12 PM |
| Using rectifier tubes in parallell | bequerel | Tubes / Valves | 3 | 8th June 2005 06:43 AM |
| Rectifier tubes | yuval | Tubes / Valves | 8 | 14th June 2003 06:40 AM |
| Page generated in 0.08963 seconds (57.55% PHP - 42.45% MySQL) with 10 queries |
