| diyAudio Sponsor | ||
Hi everyone im new to the valve amp scene but have one question me being thick... what is ment by push and pull amp also whad does the linear part mean
cheers barrie
hifi-nut |
#2 |
push-pull is a two device setup.
one tube amplifies the top half of the waveform, and the other amplifies the bottom half. The crossover point makes the difference between class A, AB, B.. It's like a two-handled saw. |
#3 |
diyAudio Moderator Emeritus
Being new to a subject doesn't make you thick!
When you ask what 'the linear part' means, do you mean 'ultra-linear (UL)'? If so, that's just a term coined by Hafler and Keroes in the 1950s for a way of usiing tetrodes or pentodes so that the screen grid is connected to a tap on the ouput transformer primary winding, between the tube's plate and the positive (B+) rail. This arrangement is meant to give the best aspects of both triode (low output impedance and low distortion) and pentode (high efficiency and power). UL has become very common since the 'fifties, and can be used either single-ended or push-pull. If you want to learn more about tube audio, you could look at Max Robinson's 'Fun With Tubes' site. Max is a retired college teacher, his website is easy to navigate and it contains quite a lot of info on tube circuitry for both audio and radio, in a non-technical way. Later, if you become really interested, you might want to invest in a good book such as 'Valve Amplifiers', third edition, by Morgan Jones. |
#4 |
Thanks Ray Moth, that was a good link for information
Steve @ Apex Jr |
#5 |
Many thanks Guys and thank-you for the link
regards barrie
hifi-nut |
#6 | |
www.kta-hifi.net |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| Why do some Bogan amps sound so good as guitar amps? | amperex | Instruments and Amps | 7 | 22nd June 2006 11:46 AM |
| Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? | percy | Chip Amps | 31 | 13th January 2006 01:33 AM |
| Page generated in 0.10652 seconds (78.25% PHP - 21.75% MySQL) with 10 queries |
