how to preserve copper plates?
Old 18th July 2007, 08:26 AM   #1
jarthel is offline jarthel  Australia
Default how to preserve copper plates?
There are a lot of projects out there where the top cover of the wood chassis uses copper plates.
How do you prevent the copper plate from oxidizing? maybe it requires regular wiping. then again only the top portion can be wipe.
thank you.
Old 18th July 2007, 08:51 AM   #2
john is offline john  Philippines
john's Avatar
You can delay the oxidation process of copper plates by applying clear gloss laquer, chrome, nickel,silver... plating, powder coating and painting.
I have used copper plates on my DIY amps which were polished and laquered, chrome plated and silver plated. The polished and lacquered plates looks good with the black-ash hard wood panel.
As time goes by, tarnish can be seen on some areas of the plate after a few months. Humidity of the listening room can also hasten the tarnishing of the copper plate. Heat generated by the amps components is also a factor.
You can delay the oxidation process on the copper plates, but it cannot be prevented.
John
Old 18th July 2007, 08:51 AM   #3
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
On a small 1-tube line amp I built,I used double sided PCB soldered together for the chassis..after a couple months,I polished it up and sprayed it with some clear spray paint stuff to protect it.
Still looks shiny to this day,sitting all alone in the junk box.
Old 18th July 2007, 09:13 AM   #4
R.I.P.
send them away to be polished and gold plated
regards Andrew T.
Old 18th July 2007, 10:49 AM   #5
Burnedfingers is offline Burnedfingers  United States
I used a copper plate when I built my Aikido line stage a few years back. I finished it with a light grain finish and sprayed it with clear laquer. It still looks the same as when I put it together.
Old 18th July 2007, 11:14 AM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Clear lacquer should work well.
Old 19th July 2007, 12:30 AM   #7
kevinkr's Avatar
I built a bunch of copper chassis 300B amplifiers around the turn of the decade, and the last time I saw one a couple of years ago the copper was still unoxidized. They were buffed and then subjected to a 3M clear powder coat which even with the baking takes weeks to fully harden, but once hard is extremely durable.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th July 2007, 06:35 AM   #8
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
I got fed up and just gave my last one a silver hammerstone coat...
Old 19th July 2007, 11:36 PM   #9
thank you
Old 20th July 2007, 09:16 PM   #10
valveluver is offline valveluver  United States
Default Copper preservation
Try "BRASSO" brand polish. It works in bug copper lugs.
how to preserve copper plates?Hide this!Advertise here!
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
Machined Face Plates drdokman Parts 40 10th March 2004 12:53 AM
JE Labs 300b round 2 1/2 Copper Plates TubeHound Tubes / Valves 18 9th April 2003 12:30 AM
mica plates Kilowatt Parts 1 19th November 2001 06:08 AM
