| diyAudio Sponsor | ||
Hi
About to start building my 300b power amp with seperate power supplys. I know the low voltage transformers i have had wound will give me more than 5 volts and 6.3v respectively( for 6sn7 in srpp feeding 6ca7 which then drives the 300b). In albury v out of power point is 253v AC whereas they have beeen wound for 240V. I plan on using resisors to trim the voltage to the desired voltage for the heaters.. then i read the thread re incorporating a 15mH choke (for speaker building as an example) into a dc supply.. problem is i am short on space in psu. My question is. Are dc heaters absolutely essential for my amp ( i have hum pots at the ready for the 300b side of things- but what of the 6sn7/6ca7 side of things?) If dc for the heaters is not essential for low hum/ripple then what is the next best thing? I could just do rc fliters i know but if the lc versions are markedly better then i will have to bite the bullet and go with the inductors. Thanks for any advice/help Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt." |
#2 |
You can use AC but their will be a small amount of hum. You can try to get rid of it with a hum bucking coil, etc.
Or you can run the filaments on hf ac. |
#3 |
when I made a 300B amp a few years ago, I used AC on the filaments with a hum pot on the 300B filament. I still got a small amount of residual hum with my 96dB speakers even with an offboard regulated B+ supply and DC for the input tube filaments.
If I was going to build it again, I would try DC using a common mode choke or try DC current regulation. |
#4 |
Thanks to AK47 and KStagger
Given my level of experience, i was wondering wether you could supply a diagram if possible. Where can i get the choke you speak of stagger? I live in australia and we do have rs components here or i will order from mouser if needed. Thanks again Nick
| Page generated in 0.07271 seconds (75.41% PHP - 24.59% MySQL) with 9 queries |
