diyAudio Sponsor
Old 13th July 2007, 03:33 PM   #1
Ty_Bower's Avatar
Default Power supply filter mod
I have a 330-0-330 volt power transformer, solid state rectified into a CRC filter. C1 = 220 uF, R = 47 ohm, C2 = 440 uF. B+ for stereo push-pull EL84 tubes (four tubes total) is taken off C2. I'm seeing about 390 volts here, which might be more than I would like. The EL84 are cathode biased, so they aren't seeing all of that across them, but it still seems like a lot to me. I've got them biased between 31~33 mA to keep overall dissipation down.
I'm considering replacing the R with a 150~200 ohm, 15 watt cemented resistor. I expect this will burn an extra 15~23 volts, bringing the B+ down into my comfort zone. It has been warned (by more than one) that I might hurt the amp's ability to respond to transients by increasing this resistor. Any thoughts?
Should I just leave it alone? The tubes don't seem distressed. I have nothing else to compare, but it seems like it sounds pretty good the way it is now.
Old 13th July 2007, 03:43 PM   #2
Tweeker is offline Tweeker  United States
One way to drop voltage without effecting regulation would be to put a zener on the center tap.
Be sure your foil hat has a good low impedance ground.
Old 20th July 2007, 09:31 PM   #3
Go to a choke input filter.
Old 21st July 2007, 01:50 AM   #4
Ty_Bower's Avatar
I thought about it. It'll drop the voltage to around 280V. I was hoping for something nearer 360V or so.
pi-filter Power supply for Alephs Stefanoo Pass Labs 25 4th May 2007 03:38 PM
how to filter a switching power supply? space-cake Class D 1 11th March 2007 01:56 AM
Dimensioning LC power supply filter Stefano Power Supplies 7 17th December 2005 07:44 PM
How do I diy Hi-End filter power supply and power cord? bmpa Parts 6 24th April 2004 12:12 AM
Why not put filter caps in power supply? Joshua Layne Chip Amps 7 31st January 2004 03:50 PM
Page generated in 0.08022 seconds (65.37% PHP - 34.63% MySQL) with 10 queries
