| diyAudio Sponsor | ||
Can any one direct me to a good simple KT88/6550 design? Looking for push pull with ultralinear, probably operating in class AB1. Want around 100 watts, which the KT88 should easily do.
Has anyone got a design for some output transformers that could suit such a design? I want to get some prices on having some OPT wound, otherwise my only option would be one of the Hamonds such as the 1650P. |
#2 |
--Sherman |
#3 |
While 100W is quite achievable with a single pair of KT88, with current production tubes that is really pushing it. For good long term reliability I would recommend a quartet of them in UL PP with plate voltages not significantly higher than 500V.
About 60Wrms is the most I would ask from a pair. I designed and built a few 120Wrms per channel stereo amps commercially using 6550 and KT88 and achieved good reliability. Incidentally the current JJ KT88 seems to have build quality issues, and I have had reliability problems with them at >525V. (Catastrophic failure is an understatement.) I would check with Jim McShane for his take on the current best bets sonically and reliability wise.
www.kta-hifi.net |
#4 |
hey-Hey!!!,
I'd question the good sense in building a max-power/AB1 design. Or a parallel PP design for that matter. If you need that kind of power, get tubes with bigger plate dissipation ratings. cheers, Douglas
the Tnuctipun will return |
#5 |
I built a prototype mono-block several years ago using a quad of Ultralinear connected KT88 driving a Hammond 1650T. It was very good but other projects took priority and the second channel never got built.
I used a CAE Dynaco MK4 front-end board to drive 6SN7 cathode followers to drive 2 pairs of KT88. I would probably do it a bit differently if designing it today BUT it may give you some ideas. Schematics for the Amp and Power Supply and a "brag" document can be found on the Projects pages of Evatco website. Its the 4th project down at this link. http://www.evatco.com.au/project.htm |
#6 |
Jim McShane reccomends several tubes KT88 wise, he sold me the gold lion reissues.
Evan
Yeah... it seemed like a good idea at the time. |
#7 |
Get your tube vendor to tap test'em on burn in. I've had Svet 88's and JJ 88'S making rude noises when pushed at 500V+. Worse with KT90 when internal shorts occurred so regulary that I had to fit a fuse in the centre tap o/p tranny.
Running 6550C at 460V max in parallel pairs UL p-p should get one close to 100W around 2K a-a. Don't go and ruin the performance by using a crappy driver stage. The 6550C new version quotes 100K grid leak in fixed bias. I use half this but demands a slam driver stage capable of 50+50V rms at low Z at low thd. Once I get the software to run I will post suitable circuits. The drawback is power supply issues...For "full pull" in a stereo pair in AB1/2 one is looking at a psu capability of 8x 0.15Ax470= 565 Watts with some reserve headroom for transients. I use a 1kW beast for min B+ volt drop between min and max sig. Amp weight becomes a measurable issue. A skimpy psu will ruin performance. richj |
#8 |
I just completed modifying an ELLA kt88 amp to run 100watts rms per channel.
Running the plates at 600vdc @ 140ma each and a pair of hammond 1650R output transformers. B+ using Cree schottky diodes (bridge) and a power transformer from ebay China that supplies 550vac @ 750ma (and 3x6.3@5a and a 70v bias tapping)several Rubycon 450uf @400vdc in series parallel. I need a choke that can handle 500ma and still fit under a 2" tall cassis if anyone can help. Quad of re-issue gold lion kt88's. Not expecting the tubes to last any where as long but it's holding up so far and makes a lot of smooth noise. Just to see if it can be done easily. |
#9 |
Just to chime in on power available from a pair of tubes, and the need for good quality tubes.
I fixed up a bass guitar amp that put out over 80 watts from a pair of EL34 tubes !! It achieved this with a voltage doubled power supply mof 700+ volts. It blew fuses regularly, and when I looked, it had a pair of el-cheapo chinese noname EL34s in it. I put in a pair of Sovteks that were said to be rugged, and no more problems were had. Now if it can get 80 watts reliably from 2 EL34s, then I am sure 100 watts can be done with KT88s as well, but as others have said, you might need to choose good quality tubes. |
#10 | |
| New kt88's or 6550 | nhuwar | Tubes / Valves | 35 | 18th April 2009 02:02 AM |
| KT88 and the 6550 | duderduderini | Tubes / Valves | 56 | 28th October 2008 04:47 AM |
| KT88 or 6550 | cjng74 | Tubes / Valves | 4 | 25th November 2007 12:33 AM |
| KT88 or 6550? | castlesteve | Tubes / Valves | 3 | 7th June 2005 10:27 PM |
| Page generated in 0.11137 seconds (79.38% PHP - 20.62% MySQL) with 10 queries |
