diyAudio Sponsor
Old 11th July 2007, 11:00 PM   #1
Default Quick Ecl86/6gw8 Amp
Hey guys,
I recently got adquired a Hammond AO-44.
Here is the schematic for the amp -->
I added a 1/4 jack in it and got some 15w speaker and it sounds nice, but when i turn up the volume it has a LOT of BASS.
I am using a single 4ohm speaker for now, i am going to get another one and connect it in series to see if it still sounds so bassy with the 8ohm load.
I want to mod this amp into something that will have a nice distortion and i have a spare ECC82.
Q: what would happend if i use the ECC83 inside the ECL86's for the preamp and use an additional ECC82 for the phase inverter?
Is this possible or i would HAVE TO use the triode section of the 6GW8 as the phase inverter?
I dont want to completly tare the amp out, just change some values araund so i can make it sound better. i am fairly new with tubes and i been fishing araund for schematics....
Can you guys please give me some sugestions?
i would apreciate it very much.
Old 11th July 2007, 11:51 PM   #2
Tom Bavis's Avatar
You can leave the amp section alone and add another gain stage and tone controls. Fender and most of the other guitar amps use a tone control section that has a notch in the lower midrange, which generally sounds better than a "flat" response with a guitar.
Look at ax84.com for some circuit ideas.
Old 12th July 2007, 02:48 AM   #3
Thanks!.
i am still curious on using the triode sections of the ECL86's as the gain stage for the amp and using an ECC82 for the phase inverter.
Supposing is possible to do that,
What set up will create more distortion?
1)
INPUT-->GAIN STAGE (ECC83)-->PHASE SPLITER (ECC82)-->PP-->Output
or
2)INPUT-->GAIN STAGE (ECC82)-->PHASE SPLITER (ECC83)-->PP-->Output
I found this Marshall schematic online and its pretty easy to follow thru....
Questions arrised as i looked at this amp tho.
1) Is the ECC83 here used for tremolo only?
2) no feedback is used on this amp ?
WILL APRECIATE YOUR HELP VERY MUCH,
THANKS!
ECL86 - quick and dirty beamnet Tubes / Valves 44 1st April 2012 06:54 AM
6gw8 /ECL86 El Cheapo modifications bbuz Tubes / Valves 13 24th June 2008 01:16 AM
Substitute for 6gw8 in Heathkit aa-32 oldheathkitphil Tubes / Valves 3 22nd May 2007 11:20 PM
6L6 for a beginner, plus ECL86/6GW8 jsp Tubes / Valves 22 8th April 2007 10:09 PM
Help with 6GW8/ECL86 tubes?? fluckscapacitor Tubes / Valves 5 11th October 2005 02:46 AM
Page generated in 0.07411 seconds (73.06% PHP - 26.94% MySQL) with 10 queries
