Old 11th July 2007, 05:16 AM   #1
pwan is offline pwan  United Kingdom
Default PP amp using 6p15P
My friend having 6P15P, 6N1P, 12AX6 & transf 250-0-250 - 250ma) around. Could you advise the good PP schematic that make use of these parts?
Thanks!
Old 12th July 2007, 03:15 AM   #2
6p15p = SV83 = EL84N. The thing to watch out for is the fragile screen grid.
Follow the general pattern of the Dyna ST35. 12AX7 voltage gain block DC coupled to 6n1p "concertina" phase splitter. Both small signal tubes would be shared between the 2 channels.
SS rectify the B+. A separate filament winding, with a CT, for the 6n1p is a good idea. The CT is used to bias the heater off B+, which ensures the heater to cathode potential limit is not exceeded..
Are there any filament windings on the 250-0-250 power trafo?
Eli D.
6P15P Tubes: Push Pull Possible? maal1605 Tubes / Valves 95 15th May 2013 11:11 PM
6P15P hybrid amp schema? L30N^_^H34RT Tubes / Valves 16 19th January 2008 05:20 PM
New SE 6P15P project chrish Tubes / Valves 21 21st December 2007 04:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 20.00%)
Copyright ©1999-2013 diyAudio
