Time for another round of "Criticise my Circuit"... err..I mean Time for another round of "Criticise my Circuit"... err..I mean - diyAudio
Old 11th July 2007, 04:11 AM   #1
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
Talking time for another round of "Critisize my Circuit"... err..I mean
Have been playing with this circuit in EW8 and CM2K for a couple days now and it appears it may make a good preamp. Just gonna post a few pics, comment if you would like.
the circuit..
Old 11th July 2007, 04:16 AM   #2
jerluwoo's Avatar
The fourier analasys at 3V rms into 600ohm.
Old 11th July 2007, 04:17 AM   #3
jerluwoo's Avatar
AC analysis at 3V rms into 600ohm.
Old 11th July 2007, 01:10 PM   #4
On Hiatus
SY's Avatar
Well, you DID ask...
Why use a tube with lousy distortion performance?
Why use a quasi-complementary emitter follower? There's much simpler and better performance options.
Is that really a 47uF output coupling cap? I'm unaware of any actual 600R loads out there.
Why use the diode on the tube's grid?
Why bias the tube in such a place as to risk grid current distortion? LED bias is good, but for a line level signals of 1-2V peak, distortion will be much higher than predicted and of a particularly obnoxious distribution of harmonics.
Modeling is fine, but a few minutes on the test bench will be very educational.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th July 2007, 05:56 PM   #5
jerluwoo's Avatar
Humor if you will. Consider the circuit in the first post to operate identical to the one posted here. I have replaced V2,3,and4 with transistors. So now we dont have to worry about heater reference for the top tubes. True no amps I know of eaither with a 600 ohm impendance but I used it to give an example of how much it can drive. Even at 5k load the distortion dropped to .003% and entirely 2nd harmonic. And yes true the 12au7 is a lousy tube but its the most accurrate model I have. The diode on the grid is to keep the grid from being pulled to a positive voltage before the tube is warm as is used in many of the circuits over at The Tube Cad Journal. After the tube begins conducting it becomes reversed biased and can be considered out of the circuit. I do wish I had the equipment to do bench testing with but alas all I have is a dmm and an "old" oscope that is suffering from tube failure in the vertical deflection amp. Not sure why the output is quasi complimentary as it is just a current sink loaded emitter follower. The lower transistor doesnt supply any ac current to the load. I am using the led to bias the tube and create a constant voltage source to bias the transistor using the cathode current so that the outputs dont begin conducting until the tube does.
Old 12th July 2007, 06:07 PM   #6
jerluwoo's Avatar
I also am quite aware of that distortion in sims is definitly not real world but rather shows trends, meaning that what reduces distortion in sims will reduce them in reality but by how much etc. will not be correct. Anyway keeping that in mind the fourier for the bjt circuit at 3Vrms into 5k load.
Old 12th July 2007, 06:16 PM   #7
jerluwoo's Avatar
Fourier of the all tube circuit at 3Vrms into 5k load.
Old 12th July 2007, 08:48 PM   #8
On Hiatus
SY's Avatar
There's nothing to pull that grid positive. Note where Broskie uses those diodes (BTW, this is an old scope trick, not original to John)- at the input, all it is is a parasitic capacitance that gets you nothing.
I don't mean to be rude, but if you want to play with circuit design, you need a scope just as much as someone who wants to work on cars needs socket wrenches. A good second-hand scope is not a very big expense and it is absolutely essential to do anything past assembling kits.
You can put together a very accurate and sophisticated spectrum analyzer for about $100, the price of a sound card and an input buffer.
Once you start playing with actual bits of glass, metal, and vacuum, you'll find very quickly that you can put together something very simple that will outperform most trick circuits.
Old 12th July 2007, 11:41 PM   #9
jnb is offline jnb  Australia
(haven't checked but...) Is that circuit designed around the aikido?
Old 12th July 2007, 11:52 PM   #10
On Hiatus
SY's Avatar
It's not an Aikido, it's an SRPP. The SRPP is a good choice for very large swings, but brings little to the table at preamp levels.
Time for another round of "Criticise my Circuit"... err..I meanHide this!Advertise here!
Its time to rehash the good ole "Which Cartridge" question duderduderini Analogue Source 82 11th August 2009 08:36 PM
the term "Time Symmetry" means....?? redrabbit Parts 1 13th February 2008 11:11 AM
Round radiating tweeter, aka "Enterprise 1" tweeter! tubee Multi-Way 39 13th May 2007 09:03 AM
Copyright ©1999-2017 diyAudio
