| diyAudio Sponsor | ||
Hi, just wondering if it was possible to add a 'parallel-feed' type arrangement to a DRD circuit, as described by Electra-Print's DRD 300B? Would the choke go before the transformer and before the Ultrapath cap? Where would the coupling cap go?
Finally, would adding a high value cathode cap to the 300B (that was larger than the ultrapath cap) assist in reducing PS noise? Say a value 3 to 4 times larger? |
#2 |
Gavin is really lousy about including any searchable terms in his posts (like parafeed, monkey, drd, 12b4, etc. which are now here so I can find this stuff again), so you would never turn these up, but these two threads (including the links in them) might be helpful:
Will this circuit work? Serious case of brain fry. You out there Thorsten?
http://www.ecpaudio.com |
| 6AS7 Parallel Feed Amp | lcsegeng | Tubes / Valves | 7 | 9th August 2008 02:17 AM |
| Isolating parallel feed amplifiers | neazoi | Tubes / Valves | 6 | 24th July 2008 10:51 AM |
| Magnequest B7 parallel feed transformer for sale | MiaTele52 | Swap Meet | 3 | 16th January 2006 03:42 AM |
| seeking: tube for a SEP parallel feed like an EL84, but with a lower Ra | aletheian | Tubes / Valves | 30 | 17th November 2005 04:24 AM |
| Parallel feed OT | Bas Horneman | Tubes / Valves | 25 | 12th February 2003 02:07 PM |
| Page generated in 0.08890 seconds (65.06% PHP - 34.94% MySQL) with 10 queries |
