| diyAudio Sponsor | ||
#11 |
I have two of the 9 pin sockets, gold plate, that I'm not going to use. I did solder wire to it, so they are not completely unused. the're the 9 pin teflon at welborn labs site, 9PCHCD:
http://www.welbornelabs.com/sockets.htm man these were $88 a piece! I'd be willing to part with these for half? $44 for the pair. I also have glasshouse boards to go with them: |
#12 |
I will say that these are high quality sockets and well made...
As for how they effect performance of audio.... I would say that it depends on the application... If you have small signal tubes then the effects are small to negligible... If you are using a 211 or an 845, then examine the AC voltage swing on your load line....This can have roughly a 2000V AC swing, which now puts a sever gradient upon the dielectric, thus having an affect on high frequency performance... I would also say that pentodes in octal base would have more of a affect....due to the higher source impedance... Chris |
#13 |
They flow.
Ceramic and plastic sockets made in 1930'th still look like new. What will happen with teflon sockets?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#14 | |
#15 | |
#16 | |
#17 | |
John |
#18 |
I have been using those china made telfon sockets for a while already. They costed me around USD12 each for Octal or UX4 in Hong Kong. Depend on your application, if you are using PCB, don't bother to use them. I would recommend using them on power tube with point-to-point wiring. The major difference between them and the traditional ceramic sockets is not about electrical leakage but the amount of mechanical vibration. As you know, power tubes, especially those direct heated ones like 300B, are quite susceptible to external vibration. These telfon sockets allows a 300B to sit solidly up-right and yet their elasticity offers better mechanical damping than ceramic. Another bonus I find during the course of using them is that telfon is such a slippery material that they don't leave scratch on the center-pin of your expensive power tubes as you insert or remove them. The contacts were so designed that they can make good contact with the tube without applying too much contact pressure. I would call this a very well-engineered and user-friendly feature. Just imagine, how horrible it is to force a expensive tube into a tight socket and breaking the centre-pin when pulling it out.
The assembly qaulity of the China make is not as good as the Japnese one so a helpful hint when using the china made telfon sockets: always check the tightness of the lock-nut on every single pin. Always retighten them until the spring washers become fully compressed. Then apply a thin coat of solder between the thread and the nut to further secure them. Sonically, I find they do not make any tonal difference from the ceramic or plastic one but they do improve very much on the stereo imaging and sound field stabilty. I got some photos of how they look in my 300B SE amp. I will post them later. Regards, P.S. try to stay away from those small 9-pins telfon socket. Their pins are so close together. It is nightmare to work with. |
| FS NOS Teflon 7pin sockets | shane_ceglar | Swap Meet | 0 | 23rd October 2007 06:16 AM |
| Tubes / teflon Sockets | 316a | Swap Meet | 27 | 3rd October 2007 09:01 AM |
| FS: Yamamoto A08-S tube amplifier, mint condition | AD | Swap Meet | 2 | 26th January 2007 04:07 PM |
| Yamamoto Sound Craft A-08 Amplifier | bigbulb | Tubes / Valves | 0 | 9th May 2005 12:14 PM |
| Yamamoto YC-02 MC cartridge on Teres | saffier | Analogue Source | 1 | 5th February 2005 04:52 AM |
| Page generated in 0.11465 seconds (72.84% PHP - 27.16% MySQL) with 11 queries |
