new thread, 6BM8 PP build begins...
Old 10th July 2007, 05:24 AM   #1
Nanook is offline Nanook  Canada
Nanook's Avatar
Default new thread, 6BM8 PP build begins...
so I've finally found the circuit (ASL AV-8 amp), and power supply (5AR4 tube rectified PS).
I just ordered the parts, less tubes, and iron--$110 USD or so. To my suprize, the capacitors and connectors were where the lion's share of the money went. I figure that with tubes, and a chassis and iron, perhaps $250 USD.
And I'm hoping to have it done for the Vancouver Island DIYfest (July 28). I'll post the build results, schematic and my parts selection for those that may be interested.
morayj will be providing the iron (thanks mr. james ), my friend John will be providing some expertise and some small parts, and pcx for the ordered parts.
Once I get the power amp section working, I want to create a preamp w/phono stage, and internal 3 inputs, so I can have me an intergrated. When functionally complete, I'll start looking at cosmetics.
If any want to chime in please do so. And please, I'm no tube geek, so if you are, please don't ask me a bunch of technical questions. I am sure the tube geeks know way more than I do.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 11th July 2007, 03:11 AM   #2
Nanook's Avatar
Default Mod ...please kill this thread
as no one has shown any interest.
Old 11th July 2007, 03:51 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: new thread, 6BM8 PP build begins...
Can you post the schematic.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th July 2007, 07:11 AM   #4
Audio_idiot is offline Audio_idiot  Malaysia
Nook,
If you go for high quality transformers, your total outlay will easily triple in a hurry... So do watch out for what you wish for.
Cheers
Audio_Idiot
Old 11th July 2007, 07:33 PM   #5
svokke is offline svokke  Belgium
I'm also building something like this. I just made a prototype using some scrap transformers and four 6bm8 from the junk box. Output transformer is a hammond 125E.
My layout is voltage gain stage direct coupled to the cathodyne phase splitter. The output stage is class AB penthode with fixed bias.
The power supply is regulated with a string of zeners and a mosfet in "cathode follower" configuration. Unregulated voltage is 300V DC, regulated it is 250V.
I'm looking forward to see your schematic.
In illusion comfort lies
Old 11th July 2007, 07:50 PM   #6
Nanook's Avatar
Default Maybe I'm "too" sensitive...
I just figured that with no replies in a day or two, no one was interested.
Dave: I'll attach the schematic... the power supply portion isn't complete (it's a 5AR4 tube rectified one)
I have suitable iron,. original power transformer , original out put transformers, and Moray's old Wav-8 trannys (thanks to morayj--when the mail gets here ).
THe caps and connectors and sovkets cost a little bit of money, and I have looked at the costs of transformers. The goal is to create a tube intergrated with phono stage and one other input, a decent attenuator (Precision Electronics from Toronto), decent power switches. The changes that I have made are the 5AR4 tube rectifier and the inclusion of a couple of Black Gate capacitors (.47 uF) in the inputs to the pentodes.
Some like capacitors prior to the AC chokes, some after. The 5AR4's can tolerate 60uF in the filter. Please have a look. Any comments are welcome. As I have stated several times before, I am no amp guru, so if "too technical" questions, I will divert them to someone else.
Anyone else watch "Little Mosque on the Prairie" last night.?I forgot how lucky we are here in good old canuckland to have some seriously funny tv from the CBC, CTV, Global, and CITY.
Old 11th July 2007, 09:01 PM   #7
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
If you're using the Wave 8 power transformer, you'll need a full-wave bridge rectifier. The two diodes in the 5AR4 can form half of that bridge, and two solid-state diodes form the other half. You'll also need a 5V transformer to light the 5AR4 - it needs be isolated from other heaters. The filter must be capacitor input with this transformer, to get enough voltage. The choke should be low-resistance as well, as there isn't a lot of voltage to work with.
Old 11th July 2007, 10:51 PM   #8
Nanook's Avatar
Default stock schematic...
here's a copy of the stock schematic. (not my page)... HERE
Old 13th December 2007, 06:08 AM   #9
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Default Re: 6BM8 PP progress?
Hi Stew,
I just stumbled on this thread in my search for the ultimate 6BM8 PP amp project/design. Any progress on your build?
Jeff
new thread, 6BM8 PP build begins...Hide this!Advertise here!
Super Triode Connection Amplifier Build with 6BM8 and 6AK5 DerFly Tubes / Valves 35 3rd November 2009 07:45 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 06:16 AM
The ESL Build Thread BillH Planars & Exotics 172 8th November 2006 09:01 PM
Copyright ©1999-2017 diyAudio
