diyAudio Sponsor
Old 10th July 2007, 03:36 AM   #1
eeyore is offline eeyore  Australia
Default KT88 Heater Current
Trying to finalise the power transformer in the Uniamp circuit, and it has a pair of KT88 in P-P. The stated heater current draw for each KT88 is 1.6A. Will there be a big issue if the transformer can only supply 3.0A overall, so each KT88 will only have 1.5A of current @ 6.3V? Thanks!
DF
http://diy-audio-blog.blogspot.com
Old 10th July 2007, 03:53 AM   #2
If the transformer can't supply enough current to produce 6.3 volts across the load (the heaters), you'll get less voltage. You can't reduce the current and expect to maintain same voltage- blame George Simon Ohm and his darn law. You'll also likely end up with an overheated transformer. It's desirable to operate the heater at its rated voltage, but others here are for more knowledgeable about what happens if you don't. There's certainly some tolerance, as line voltage goes up and down. I'd run a test to see if the transformer has enough margin in its design to do the job anyway.
Old 10th July 2007, 04:10 AM   #3
Thanks Conrad, so let me do some quick maths...
V = IR
6.3 = 1.6 x R
=> R = 3.9375
If I = 1.5, R remains constant,
=> V = 3.9375 * 1.5
=> V = 5.90625 V
If there is 5% in line voltage variation, meaning that 6.3V is somewhere between 5.985V to 6.615V. : If there is a 10% line voltage variation, then the potential voltage is 5.67V to 6.93V. Am I doing something wrong, or on the right track?
Further, I have read on this and other places, that running the heaters at a slightly lower voltage is not a detriment? I think that some even suggest that it sounds better and that it could prolong the life of the tube?
DF
Old 10th July 2007, 04:15 AM   #4
You are on the right track. There may be some variation in R with current, but I don't know how much. I know high heater voltage is bad for tube life, but far less about where the "sweet spot" might be!
Old 10th July 2007, 12:00 PM   #5
jeapel is offline jeapel  Canada
the sweet spot for long life is 6.1v from my research
in internet
Old 10th July 2007, 12:05 PM   #6
but below 6.0v it s bad for the cathode
Old 10th July 2007, 12:10 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Hasn't is occurred to anybody that the valve manufacturers probably knew what they were doing? When they said 6.3V, that's what they meant.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th July 2007, 12:55 PM   #8
6.3V comes from the days that you were powering the heaters from 6V batteries, manufacturers choose 6.3V to compensate for fresh batteries. I have read this in a dutch book from philips about their MiniWatt tubes.
Old 10th July 2007, 01:24 PM   #9
Yvesm is offline Yvesm  France
Yvesm's Avatar
Yes, yes and yes to all !
But, who really measured how much current the tubes draw in true word ?
Allow some room for manufacuring tolerance . . . as usual.
Here:
http://frank.pocnet.net/sheets/084/k/KT88.pdf
they explicitly write Ih (approx) ....1.6 A
Conservative engeenering practice should be to consider that ALL the tubes you will use will keep 10% more than average, so design for 1,8A xeye:
Optimists or bean counters will design for 1.44 !
But consider that you transformer will be overloaded by only 0.65 watts.
Plug and go !
Yves.
Old 10th July 2007, 01:25 PM   #10
EC8010's Avatar
Default Evolution
As you say, 6.3V originally came from batteries, but you're not proposing that GEC intended that their KT88 should have its heater powered from a battery?
29GK6 heater current? bst Tubes / Valves 6 4th October 2010 02:21 PM
Constant Current DC Heater Supply bwarden Tubes / Valves 10 8th October 2007 04:29 PM
Heater current drawn by 8416 pchw Tubes / Valves 3 5th October 2007 03:54 AM
Heater current monitoring... nickds1 Tubes / Valves 2 9th November 2006 08:22 PM
Page generated in 0.11374 seconds (76.71% PHP - 23.29% MySQL) with 10 queries
