150V plate output tubes
I've got a couple of beefy 230:115V transformers which I wanted to put in use. Do you have any suggestions on power tubes which may work good with low voltages?
I've got a couple of SE output transformers with 10K and 5K primaries.
Of course, more output is better, ST octal is better than 9-pin envelope, cheaper is better than expensive etc. I thought about 6G6G output but 1W is not that much.
Don't ignore the idea of using secondaries configured as voltage doublers or even triplers, if windings are suitably current rated. Many early amp designs used this technique using cheaper TV components. There was one in particular..name lost..perhaps other members know.
Hint: if there is enough room between bobbin and outer core limb on an E/I core one can often wind a few turns for the heater. Even easier with toroid without centre.
richj
