Old 8th July 2007, 06:01 PM   #1
andrew_whitham's Avatar
Default drift in direct coupled tubes
hello all.
I'm looking at a direct coupled input stage which runs something like a CCS loaded ECC88 into an equally CCS loaded 12BH7 cathode follower. Picture the front end of a Willamson amplifier but the concertina is only driving from the CF output
so far no drama.
my query is then, how does the amp deal with drift of operating points over the life of the tubes? My concern is that even a small change in the steady state anode voltage messes up the operating point of the second tube.
Can anyone shed some light on this? is the drift actually very small? or is some other process going on?
Apologies if this is actually self evident - clearly direct coupled amps work (well) but I'd rather like to understand why...
cheers
Andy
Old 8th July 2007, 06:50 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The anode voltage of the first stage may well drift, but it doesn't matter because the cathode follower isn't really very bothered about its Vak and it has lots of feedback wrapped around it. Imagine that second stage (before feedback) as having a flat loadline due to the CCS, then all that's happening is that drift from the first stage erodes a little headroom at one end of the other of the cathode follower. Now, if the second stage had gain, drift of that first stage would be far more important...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 8th July 2007, 07:18 PM   #3
Hi Andrew,
an effective method for reducing the gm for dc of the input tube is a higher cathode resistor. The anode load reduces the gm by the factor 1+ Ra/rp, the cathode load 1+ gm*Rk. Adjust the bias by a positive voltage on the grid.
Regards Andreas
Old 8th July 2007, 09:50 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Use a CCS with a servo like I do in such cases.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 8th July 2007, 10:02 PM   #5
Default Thanks
EC8010,
thanks for that, I think I see the feedback in the cathode follower is reducing the error (as it would) the cathode is tending to follow the grid anyway so its almost self compensating. Is that about the size of it?
generally though,
If the second stage has gain then, what are the likely problems? I've seen this done with a couple of *sn7 sections, and I guess it works?
I still feel like I'm missing something, If the anode voltage of the first stage changes the second stage operating point is supposed to move... Is the basic rule to assume that the operating point of the second triode is going to be 'in the general area' of -n volts? i.e. realistically you won't get full swing from the second triode?
And if so. what sort of variation is common during the life of the tube (now thats the million dollar question isn't it?!)
Does any one know of any resources that cover tube aging? although to be honest I'm not sure how I'd relate this to the above...
cheers
Andy
Old 8th July 2007, 10:11 PM   #6
waveborne, I'm fully intending to use a CCS's I already tested this out on a previous amp.
If it isn't such a daft question then how are you feeding the servo into the CCS - I assume this is what you are up to?
My scratchings this afternoon involved level shifting from the anode of the first tube and setting the grid bias to maintain a "constant" VA - no, it didnt look so pretty then either.
Cheers
Andy
Old 8th July 2007, 10:17 PM   #7
Wavebourn's Avatar
Here you go:
In order to shift levels I use bipolar B+ source.
Old 8th July 2007, 11:06 PM   #8
jnb is offline jnb  Australia
Default Re: Thanks
If you direct couple to a gain stage in the most common way, you'll first need to bring the cathode up to the grid. Using a large value of cathode resistor (like you'd use for a cathode follower) will cause the gain to drop just like a cathode follower. If you bypass that resisotr you get your gain back and your cathode voltage is fixed.
Basically, the first stage DC drift will translate to a second stage bias drift only where a volt or three makes little difference to the first stage, it makes a lot of difference at the grid of the second stage.
Old 9th July 2007, 03:12 AM   #9
ray_moth's Avatar
In the case of a mu stage, it can easily be coupled directly to a following stage, with no risk of drift, if the CCS of the mu stage consists of a MOSFET and the output is taken from the MOSFET's source. This is based on the fact that biasing the MOSFET's gate to a fixed voltage will also force its source to be at that voltage.
The bias-point can be fixed using a (capacitor-bypassed) potential divider between B+ and ground or, if you don't trust the stability of your PS, you can use a (capacitor-bypassed) zener. Connect the bias-point to the MOSFET's gate using a high value (several megohms) resistor.
Old 9th July 2007, 09:03 AM   #10
EC8010's Avatar
Andrew; yes, you've pretty much "got it." Of course, the second stage can't distinguish between a wanted anode movement and an unwanted, so your "general area" supposition is correct. Now, if you go to a differential pair following another, a common drift in anode currents is rejected (although differences are amplified). As to how to minimise drift, regulated heaters and HTs would be a good starting point; have a look at oscilloscope circuits. Nevertheless, I'm fairly sure there's an old valve book with a chapter entitled, "DC amplifiers, and why to avoid them." Pretty well sums it up, really.
capacitor coupled vs. direct coupled ouput hugobross Solid State 11 21st January 2011 01:56 AM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
My first amp - a direct coupled 2A3 Wardsweb Tubes / Valves 51 3rd August 2003 04:22 AM
Can someone explain parafeed & direct coupled & a.c. coupled? mwmitchell Tubes / Valves 2 11th September 2002 01:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
