Light bulbs as cathode resistors?
Old 8th July 2007, 03:25 AM   #1
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Default Light bulbs as cathode resistors?
Obviously for a self biased power output stage. Think it would work or would there be stabilization problems?
Old 8th July 2007, 03:52 AM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I don't see why it wouldn't work..
But I don't think light bulbs are terribly linear.
Could be interesting in a guitar amp though.
Old 8th July 2007, 04:04 AM   #3
Jeb-D.'s Avatar
Yeah, there not. The resistance increases as power dissipation/heat increases. There almost a dead short when cold. Which is why I raise the question. Just thought it would be cool for bling factor, instead of just having some power resistor hiding in the chassis. It would take some experimenting for sure, to find the right bulb.
Old 8th July 2007, 04:28 AM   #4
jlsem is offline jlsem  United States
jlsem's Avatar
Mo' betta bling would be a mercury vapor rectifier in the cathode circuit.
John
"Those who abjure violence can do so only because others are committing violence on their behalf." - George Orwell
Old 8th July 2007, 04:28 AM   #5
On Hiatus
SY's Avatar
Use LEDs.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th July 2007, 04:49 AM   #6
Jeb-D.'s Avatar
Use LEDs.
I should have been more specific, For an output stage, 60Vcg @ 250mA.
Nice idea, if I can find any that meet the circumstance.
I was thinking lightbulb that's halfway lit so it glow's orange instead of bright. Kind of like in the ZEN amplifiers.
Old 8th July 2007, 06:47 AM   #7
aletheian is offline aletheian  United States
aletheian's Avatar
Well, I have never used a light bulb in a cathode, but i have an amp running right now using the preamp tube's filaments as the cathode resistor for the output stage (class A el34 triode PP) ... which is pretty similar... so my answer would be: "go ahead and try it!"
Heghlu'meH QaQ jajvam!
Old 8th July 2007, 08:26 AM   #8
OzMikeH is offline OzMikeH  Australia
Not my amp. No idea if they are for the cathodes or not. You will notice they are part of the power supply section. They are used as slow regulators. more current = hotter filament = more resistance.
they end up about 3-5 times brighter than the tube filaments.
I suggest you experiment with a few different light bulbs, if you can't get close enough use a low value resistor to tweak the light bulb.
Old 8th July 2007, 03:40 PM   #9
radtech is offline radtech  United States
I guess you'd also have to take into consideration the possibility of the bulb burning out, opening the cathode circuit.
Old 8th July 2007, 04:45 PM   #10
astouffer is offline astouffer  United States
astouffer's Avatar
Theres a few guitar amp schematics where the preamp 12AX7 heater is wired to the output tube cathodes. Not sure if theres any advantage
Light bulbs as cathode resistors?Hide this!Advertise here!
little light bulbs in the radio scampo77 Car Audio 14 14th July 2009 02:00 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
using light bulbs when testing new DIY project jarthel Parts 20 12th May 2007 02:01 PM
VU light bulbs? Pbassred Solid State 19 25th July 2004 05:43 AM
