| diyAudio Sponsor | ||
#11 | |
I just got an isolation transformer rated at 50w, which I think should be adequate for a 2w amplifier. After this, I'm thinking of building something REALLY loopy - a 2w amplifier based off of subminiature tubes. I'm currently pondering how I can most easily build a 280 volt power supply to power it. |
#12 |
Look at Z-vex's stuff.
As for the power supply, I personally would use a switchmode power supply. Small, high power, and easy to rectify. Only problem is you have to use adequite shielding or you have problems with RF interference, especiall with guitar. However, if you are looking at less than 250mw of power (1/4 watt) I am sure that a 12v 1.5 amp wall wart and a 12v 1 amp xfrmr in the chassis wired back to back would work fine. However, for the cost you cant go wrong with the one I ordered for the model two. http://www.tubesandmore.com/scripts...P?item=P-T262E6 It is very small, and you oculd squeeze 3-4 watts out of it just fine. It wouldnt even break a sweat with submini's.
always preach the gospel- and when necessary use words. |
#13 | |
I just ordered a 50va isolation transformer, but for the submini tube amp, I'm looking to go with battery power. I'm thinking of using a small flyback transformer setup, but finding transformers rated for 50khz is kind of hard. |
#14 |
try the car audio section of this site, they will be able to help you better. For something like that you would use a small ferrite core. A 1 inch core would be good for 50 watts or so, very small. Theoreticly, if you were to only need about 10 watts of power draw, you could use a very small x-frmr indeed.
Batteries won't last long at constant current draw...Think radio controlled car at max speed for about 10-15 minuites on end.
#15 | |
Assuming an efficient buck-boost or flyback power adapter, that would leave me at least five hours on a charge. |
#16 |
This is true, however in practice run times rarley work that way. This is due to the fact that music varies so much in voltage and current output. I was assuming you were going to be doing class A, where your batteries would not last long at all. However I went back and re-read your post and saw you meant AB1. This will last longer, because READ: Properly used, tubes are very efficient in converting available power to output. HOWEVER! it is their heaters that make them inefficient power wasters. In a typical 20 watt guitar amp, including all the preamp tubes and reverb and teremelo, you are wasting over 20 watts of power just in the heaters!
#17 | |
I suppose you're right. However, this amplifier uses ridiculously tiny tubes, specifically the 6112 dual triode and the 5902 pentode (yeah, it's running in class-A.) http://jonanderson.mn.googlepages.com/ The amplifier is going to be very, very, very small - in fact, not too far off in size from the Z.Vex amplifier that you linked me to. That said, after adding up the cost of tubes (about $20 shipped), vibrator (about $20 shipped), and output transformer (about $35 shipped), I've decided that, unless someone else is paying me to build it, I'm better off converting an old battery-powered tube radio instead. |
| Conversion of Hiraga's "Le Monstre" to a Circlotron | tiefbassuebertr | Solid State | 12 | 1st May 2011 08:26 AM |
| Dual 15" party speaker | Cal Weldon | Swap Meet | 2 | 16th April 2008 12:28 AM |
| how to get best "radio", from PC-amp-speaker | gychang | Everything Else | 15 | 7th February 2008 06:30 AM |
| Clock radio speaker enhancement "project" | ukram | Everything Else | 0 | 20th September 2004 10:46 PM |
| Page generated in 0.12628 seconds (81.73% PHP - 18.27% MySQL) with 10 queries |
