Old 4th July 2007, 09:20 PM   #11
I actually built this schematic on the HF20 chassis. Power transformer runs a bit hot, but has not failed. Using KT90's.
MG
Old 4th July 2007, 09:28 PM   #12
pchw is offline pchw  United States
Hi MG,
Did you use the original Eico PT's? If so, did you use separate heater trafo? I was told that they were not even good for EL34 when I planned to build an Eico HF-35 out of them.
- Fred -
Old 5th July 2007, 09:16 AM   #13
I used all the original iron, without an additional heater supply. Everything is new but the iron, including a Hammond 159P choke in the PS. PT runs quite hot to the touch. I'm probably pushing it, but it has held together. With a GZ34, the B+ runsa bout 4230V.
MG
Vestax pmc-07 schematic parts list? djmike Chip Amps 9 10th April 2013 05:11 PM
Wanted Vestax 46 Schematic and parts list/ repair manual djmike Chip Amps 20 1st September 2011 10:39 AM
parts list or schematic for NAD C740/340 ?? d0g Solid State 1 3rd March 2009 07:43 PM
Volksamp Aleph 30 schematic and parts list needed KevinLee Pass Labs 9 22nd December 2008 02:04 PM
Weston 981 Type 3 schematic and parts list needed Apogee Tubes / Valves 0 14th August 2006 01:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
