KT88 amp schematic/parts list KT88 amp schematic/parts list - diyAudio
Old 4th July 2007, 03:55 AM   #1
kgrant67 is offline kgrant67  United States
Default kt-88 amp schematic/parts list
I am new to this whole DIY thing. I have been doing some reading online and I think I want to make a stereo amp using kt-88 tubs and hammond 1650N output and 274 power transformers. Can someone recommend where to find schematics and parts list?
Old 4th July 2007, 08:04 AM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
If you search the forum you will see Mikael Abdellah's SE KT-88 which some have built. There's a thread about that.
Old 4th July 2007, 10:46 AM   #3
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Bonavolta has some SE and PP KT88 amp schematics.
Old 4th July 2007, 01:57 PM   #4
Sherman is offline Sherman  United States
Default Re: kt-88 amp schematic/parts list
Originally posted by kgrant67
... a stereo amp using kt-88 tubs and hammond 1650N output and 274 power transformers. Can someone recommend where to find schematics and parts list?
Based on the output transformers it appears you want to make a push-pull amp. There are tons of schematics online for that and some partial kits to help you on your way.
One idea might be to build clones of Dynaco's MK III amp. You can go to TubeZone.Net and check out the driver board kits. You would need a chassis, sockets for the KT88s plus your transformers and whatever connectors you decide on.
Mikael's KT88 amp that Arnold mentioned (and that I have built and use every day) is a single-ended amp. If single-ended is OK for your needs then I can highly recommend that schematic. Very good sound with the right transformers and quite easy to build.
--Sherman
Old 4th July 2007, 04:31 PM   #5
castlesteve is offline castlesteve  United States
Default Kt88 amp.
I can second the Se amp that Sherman mentioned. Mine is used daily and sounds really nice. If your going Push Pull then you might try Diytube for their Eiclones which are PP kt88 monos.
Steve.
http://www.diytube.com/phpBB2/index.php
Old 4th July 2007, 07:14 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
You say you totally new in DIY, and want to build a tubeamp
Well, you might be able to build this one, its SE with KT88, and there is a lot of reading there too
But at least you should train your soldering skills first
http://www.tubelab.com/SimpleSE.htm
Old 4th July 2007, 07:22 PM   #7
Thanks guys. Let me ask this. I haven't heard any of these amps. The push/pulls are at higher wattage but I hear rave reviews of the se amps. Are the SE amps more efficient? Meaning, when one of those is listed at 8 watts, is it deceptive to compare that to a 25w or 50w rating of a push/pull as to volume, fullness of sound, etc.? I do like volume. And I would like them to run them through a pair of mirage frx7s (rated 25w to 100w, I believe) that I have until I get into the diy speaker thing too!!
Old 4th July 2007, 07:37 PM   #8
One thing that those coming to tubes from solid state seem hung up on is power output. It is much less important than most people think.
Consider this- a 3dB increase in volume is noticeable as being "a little louder". That 3dB increase requires double the power. In the end the difference between a 50W amp and a 100W amp is 3dB or "a little louder". If your speakers have an efficiency of 89dB/1W/1M and you change to 92dB speakers you have effectively doubled the power of your amp.
Here are some numbers-
Mikael's KT88 single-ended design should make 7 or 8 watts per channel (mine come in at almost 8).
Push pull KT88s in triode mode can make anywhere from 15 to 30 watts per channel in most schematics I've seen.
Push pull KT88s in ultralinear mode will probably give you 40 to 50 watts.
Push pull KT88s in "pentode" mode (they are actually beam tetrodes but the way they are connected is the same) will make 60 to 70 watts. Some designs can go higher.
In the end it comes down to-
* how efficient are your speakers
* what size is your listening room
* what type of music do you listen to
* how loud do you listen
I find that my KT88 SE amps play as loud as I want 99% of the time when paired with either Dynaco A25 or Advent/1 speakers (neither is particularly efficient). I listen to everything from rock to jazz to classical.
--Sherman
Old 4th July 2007, 07:54 PM   #9
maynardg is offline maynardg  United States
I build this schematic, using old Eico HF20 output transformers.
http://www.arrakis.es/~igapop/iga6550.htm
A very nice amp - top notch actually. Not quite as sweet as my KT88 single ended in the mids - but much more authoritative in the bass.
A lot depends on your speakers and how loud you like to listen. The SE is normally enough, but to rock out, you will appreciate the power of the push-pull.
MG
Old 4th July 2007, 08:20 PM   #10
pchw is offline pchw  United States
Very interesting, I also have 2 Eico HF-20's sitting in the corner doing nothing, and I don't know know what to do with them ....... Sorry for the threadjack.
- Fred -
KT88 amp schematic/parts listHide this!Advertise here!
Vestax pmc-07 schematic parts list? djmike Chip Amps 15 23rd January 2017 02:49 PM
Wanted Vestax 46 Schematic and parts list/ repair manual djmike Chip Amps 24 12th October 2016 10:17 PM
parts list or schematic for NAD C740/340 ?? d0g Solid State 1 3rd March 2009 07:43 PM
Volksamp Aleph 30 schematic and parts list needed KevinLee Pass Labs 9 22nd December 2008 02:04 PM
Weston 981 Type 3 schematic and parts list needed Apogee Tubes / Valves 0 14th August 2006 01:23 AM
Copyright ©1999-2017 diyAudio
