| diyAudio Sponsor | ||
What would the plate resistance and amplication factor of a
El34 be wired as a triode ? |
#2 |
Take a look at the Mullard data sheet, it is all there..
http://www.mif.pg.gda.pl/homepages/f...129/e/EL34.pdf Ra 910 ohm mu 10.5 Incidentally quite linear as well.
www.kta-hifi.net |
#3 |
Thanks, I had already looked in my RCA and Sylvania manuals
and it didn't have it. That Mullard sheet was right on the mark. |
#4 |
diyAudio Moderator Emeritus
Unfortunately, the info given in data sheets can vary considerably from one to another. I've sometimes had to look at several different manufacturers' sheets for the same tube before I find what I'm looking for.
As said by Kevin, the EL34 is quite linear as a triode, although there has been some debate as to whether the suppressor should be connected to the cathode as advised by Mullard, or to the plate as used by Steve Bench in this circuit. (Actually, Steve is using an E34L but I wouldn't think it makes any difference.) |
#5 | |
Hi Ray_moth,
EF91 example from my ETF06 lecture on triode-strapping pentodes. Tom
If in doubt, just measure. |
#6 |
Hi Tom,
I daresay it is much ado about nothing, just that some people reckon that one way sounds better than the other. I'm not sure that there is a majority for either way. |
#7 | |
In this regard and by all practical means it would make much more sense and it would be much easier to provide a facility for adjusting the bias voltage to "pull" the operation point within a range (not only two states like g3-strapping) somewhat Tom
| Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? | ray_moth | Tubes / Valves | 4 | 23rd February 2007 12:22 PM |
| EL34 Triode Mode - G3 where? | gingertube | Tubes / Valves | 74 | 7th December 2005 09:36 PM |
| EL34 best for triode strapping ? | percy | Tubes / Valves | 7 | 4th April 2005 07:05 AM |
| Page generated in 0.10800 seconds (78.18% PHP - 21.82% MySQL) with 10 queries |
