| diyAudio Sponsor | ||
This is my going to be my setup:
Phono ---> Preamp ---> Switch ---> Equalization ---> Active Crossover ---> High Amp Radio ---> Switch --------------------> ---> Mid/Low Amp CD ---> Switch ---> DAC ------------> Cable ---> Switch ---> DAC ---------> Computer ---> Switch ---> DAC ---> DVD ---> Switch ---> DAC -----------> Should the linestage go between the eq and cross? Or should two go between the cross and the amps? |
#2 |
if the crossover is digital, then fit line stage/volume control after the crossover. It allows the DACs to run at full welly and allows you to use digital inputs.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
My crossover is analogue. So between DAC and equalizer or equalizer and crossover? Should i just try it both ways?
Any suggestions for a linestage? All together it will be driving four 100th's. My plans are to make either the linestage or a tube equalizer a showpiece with lots of copper and glassware thanks |
#4 |
After your crossover, you'll have twice as many channels to deal with, so there's that, but OTOH each channel will have a lesser signal to handle so as early as practical sounds good.
If it were me in those shoes, I would try to put the lower distortion conponents first. In practice I would guess that many would end up with the crossovers just before the power amps. For my systems, I try to incorporate the crossover roll-offs into my other stages somehow. |
#5 | |
| C3M linestage | costa23 | Tubes / Valves | 15 | 23rd August 2009 08:53 AM |
| C3m linestage | bequerel | Tubes / Valves | 32 | 14th April 2009 06:03 AM |
| 48V B+ linestage | hirafu_boarder | Tubes / Valves | 24 | 11th May 2008 05:57 PM |
| SRPP linestage help | DoomPixie | Tubes / Valves | 7 | 5th July 2005 02:49 PM |
| Another linestage...... | kianbach | Tubes / Valves | 11 | 28th June 2005 05:34 PM |
| Page generated in 0.09508 seconds (67.11% PHP - 32.89% MySQL) with 10 queries |
