Input impedance
Input impedance
Old 23rd July 2007, 07:32 PM   #21
Shoog is offline Shoog
Shoog's Avatar
You need to think parafeed to use the interstage as a phase splitter. I encountered bass resonance with a 1uf parafeed cap, but 4uf gave a flat response. I use the DIYaudio CCS by Pinkmouse in my amp which consists of a CCS loaded parallelled 5687 driving a pair of 6AS7's. This is a difficult valve to drive and I needed a full 40mA to get it to work satisfactorily. It looks like the 813 has similar input capacitance, but I think the issues may be a bit more complex than the simple figures might suggest.
Try it with a beefy parafeed driver through your interstage and onto your 813's. If the top end is disappointing then look to add the powerdrive.
Shoog
Old 23rd July 2007, 08:10 PM   #22
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Parafeed I though parafeed was for single ended this is push pull. I'm thinking it would be fairly tricky to implament and could cause some anode load problems am I correct in thinking this our not?
Nick
Old 23rd July 2007, 08:51 PM   #23
David Davenport is offline David Davenport  United States
Hi Nick,
An example of a parafeed differential amplifier is here:
http://www.raleighaudio.com/chapter_4.htm
Dave
Old 23rd July 2007, 08:52 PM   #24
Shoog's Avatar
If your going to use the interstage to do your phase splitting, you will be going from a SE driver to PP outputs. In that case you put your parafeed cap before the primary of the interstage.
If thats not what you intend to do then I'm a bit lost.
Shoog
Old 23rd July 2007, 11:11 PM   #25
nhuwar's Avatar
the other idea I was toying with is the 6sn7's in srpp. And it would be easy to config it in parafeed this way. I don't know how well it would work though.
Nick
Input impedanceHide this!Advertise here!
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
How much input impedance is enough? Russ White Chip Amps 5 13th April 2005 07:25 PM
ZV7 Input Impedance. gl Pass Labs 0 15th February 2005 10:54 PM
input impedance bbksv Chip Amps 2 13th February 2004 11:58 PM
JLH input impedance hlyytine Solid State 12 1st February 2004 07:00 PM
