Hybrid Rectifier Check Please !
Old 4th July 2007, 07:26 AM   #11
corne is offline corne  Netherlands
With Kevin's solution the 900V B+ jumps first to 450V and then if the 6AU4 diodes are warm it goes to 900V at the same time the 400V will be available.
A delayed start of both voltages can be achieved by placing a diode between the transformer centre tab and the 4Hc hoke (anode to centre tab and cathode to choke) on the 400V B+.
This diode will also prevent the capacitors on the 400V B+ to be negatively charged.
Corne
Old 10th July 2007, 11:54 AM   #12
Steven-H is offline Steven-H  United States
Gentlemen,
Thanks SO much for all of your help. The finished product is shown here:
I am working on getting the chokes wound...Once they arrive then I should be able to breadboard the circuit and report back on a verification that this thing works as needed.
Thanks again,
Steve
Old 11th July 2007, 12:00 AM   #13
Eli Duttman is offline Eli Duttman  United States
Steve,
You need a 10 nF. HIGH WVDC ceramic cap. between the 1N4007's cathode and ground. The cap. protects the SS diode from inductive kick back spikes. You do show a choke I/P filter.
Eli D.
Hybrid Rectifier Check Please !Hide this!Advertise here!
Hybrid fullwave rectifier tubesmuggler Tubes / Valves 12 6th February 2014 07:53 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
hybrid rectifier question dr.strangelove3 Tubes / Valves 17 4th October 2005 01:28 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
