diyAudio Sponsor
Old 4th February 2003, 06:59 PM   #31
gpapag is offline gpapag  Greece
gpapag's Avatar
EC8010. Thank you again, but i think that i need your help. Applying yor method in paper, results in more than 50 times the "normal" driving current. Is it in line with yor findings, or am i totally wrong? (If you like, choose 2 tubes, driver and output, and write down the results of your calculations).
George
Old 4th February 2003, 07:12 PM   #32
gpapag's Avatar
Originally posted by James D
"...If we assume in Class A that only half of the bias current level is available for drive in a driver stage ..."
James, Thank you for your information. I have to ask you though, how did you arrive at the conclusion i quoted above. Do you apply Kirchhoff analysis method, is it a rule of thumb, or is it your observation? I was really wondering myself about that too.
George
Slew rate calculations - how much do I need? peranders Solid State 232 20th November 2011 06:02 PM
IcePower slew rate Rikard Nilsson Class D 24 29th April 2009 04:39 AM
slew rate adjustment... chipmonster Parts 7 25th January 2008 10:01 AM
Slew rate value Luke123 Chip Amps 5 7th April 2005 12:30 AM
slew rate and power output. JBL Everything Else 2 16th September 2001 10:51 PM
Page generated in 0.08617 seconds (49.92% PHP - 50.08% MySQL) with 11 queries
