| diyAudio Sponsor | ||
Looking for an octal dual triode with High Mu but with a higher Gm than a 6SL7/6SU7. Pretty much an octal equivalent to 12AT7 would be ideal.
Does such a tube exist |
#2 |
I think that does not exist...try parallel 6SL7..
#3 | |
What are you trying to accomplish, Jeb? If you have an existing chassis with an Octal socket, buy a "hole shrinker" from Bottlehead and put a 'T7 in. If you are looking to do something Octal only, you are SOL. High gm/low Rp triodes are (AFAIK) a post WW2 phenomenon found only in 7 and 9 pin mini "bottles".
Eli D. |
#4 | ||||
I found a tube 2C52 that has a higher Mu and higher Gm than a 6SL7. It's not ideal, but it may work well. Was unable to find a data sheet for it though. Anyone know where I can find one? |
#5 |
Jeb-D,
You may look at the ECC32 (mu=57, gm=3500 umho) or the ECC33 (mu=68, gm=7700 umho). They appear to be still obtainable according to advertisers on the internet. Be aware of the fact that these figures are quite operating point (Ia) dependant; these are according to my scource at fairly high current. Edit: I do not know whether the pin connections are the same as the 6SL7, should that be of consequence. |
#6 | |
http://tdsl.duncanamps.com/pdf/vm345.pdf
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#7 |
#8 |
diyAudio Moderator Emeritus
According to my information, ECC32 has mu of 32 and Gm of 2300 umho. ECC33 is not much different, with mu of 35 and Gm of 3600 umho. Their pinout is the same as 6SL7 but they may not be suitable for what you want, because mu is only ~ 1/2 of 12AT7's mu. Linearity is another thing to watch out for with the ECC33, which was designed as a computer tube!
#9 |
Dear me!
Where did my datasheet get their information? I never actually used them as far as I can recall. The original Leak TL12 did use the ECC32 I think, but all was a little long ago. Thanks Ray, this needs checking then, in which case I also cannot recall a different solution. As was said, when the demand for v.h.f. tubes (higher gm) came, the miniatures were already going; that format then became the natural choice. Regards |
#10 |
Thanks for the input guys. I think the 2C52 will probably be worth a try. While the links you guys found had some helpful data, It seems like there are no curves for this tube anywhere on the net. Guess I'll have to buy one and tweak with it.
| Audiomagus, do they exist ?? | Minimuslover7 | Chip Amps | 3 | 25th June 2009 10:26 PM |
| Does a DIY Vandersteen design exist? | areno | Multi-Way | 1 | 20th September 2008 04:31 AM |
| new rather then refurbed 12.4 do they exist? | rajtaheem | Digital Source | 0 | 11th December 2006 09:29 PM |
| Can toroidal & E-I co exist? | roshan101 | Power Supplies | 7 | 30th October 2006 03:04 AM |
| Page generated in 0.10589 seconds (81.32% PHP - 18.68% MySQL) with 10 queries |
